Subject: RE: Channel access blocking
To: "'Hidas, Dean'" <[email protected]>, <[email protected]>
Date: Fri, 1 Dec 2017 08:42:35 -0600
You could use
EPICS_CA_ADDR_LIST
And set it to the broadcast address(s) of the interface(s) that you want to
use and set
EPICS_CA_AUTO_ADDR_LIST=NO
So that EPICS will not try to use ever Ethernet adapter that it detects.
-----Original Message-----
On Behalf Of Hidas, Dean
Sent: Friday, December 1, 2017 7:27 AM
To: [email protected]
Subject: Channel access blocking
I'm using EPICS R3.14.12.3-8.  I have a (many) PC with 2 ethernet ports
connected to different networks.  Is there a simple way to completely block
channel access from 1 of them? ie, make all PVs, beacons, etc unavailable to
that interface?
Thanks for your help,
-Dean Hidas=
Re: Channel access blocking Mark Rivers
Channel access blocking Hidas, Dean
Prev: Re: EPID bumpless restart Mark Rivers
Next: dbGetLink question Mark Rivers
Prev: Channel access blocking Hidas, Dean
Next: Re: Channel access blocking Mark Rivers
