Subject: Re: Andor shamrock not detected
Date: Fri, 01 Dec 2017 19:06:41 +0000
Hi Mark,
It is on Linux. ADAndor is master branch from github. It worked before, with another ADAndor version, and AD 2-6.
Come to think of it, I might not be using the same compile vs. Runtime Andor support libs.. Need to double check that one.
Hinko
On Fri, 1 Dec 2017 at 18:04, Mark Rivers <[email protected]> wrote:
Also, how is your spectrograph connected to the computer?  Is it directly connected via USB or indirectly via the connector labeled "Camera".  The latter is how mine is connected.
> -----Original Message-----
> From: Mark Rivers
> Sent: Friday, December 01, 2017 10:51 AM
> To: 'Hinko Kocevar'; [email protected]
> Subject: RE: Andor shamrock not detected
> Hi Hinko,
> Is this Linux or Windows?
> What version of ADAndor?
> Did it ever work, or is this the first time you have tried it.
> I do recall some people at the APS having trouble with the Shamrock under Linux, but I
> think they did get it working.  It is working fine for me under Windows.
> Mark
> > From: [email protected] [mailto:[email protected]] On Behalf
> > Of Hinko Kocevar
> > Sent: Friday, December 01, 2017 10:31 AM
> > To: [email protected]
> > Subject: Andor shamrock not detected
> > Hi,
> > I have trouble talking to Andor shamrock spectrograph.
> > It fails after calling Andor API:
> > error = ShamrockGetNumberDevices(&numDevices);
> > because numDevices evaluates to < 1.
> > If I try with Andor supplied C example it works fine, I can control
> > the spectrograph.
> > Here is what the example does for initialization - and it does not
> > look any different, AFAICT, from what EPICS AD Andor support does:
> >         //Initialize CCD
> >         error = Initialize("/usr/local/etc/andor-2.102.30001.0");
> >         if(error!=DRV_SUCCESS){
> >                 cout << "Initialisation error: " << error << "
> > ...exiting" <<endl;
> >                 return(1);
> >         cout << "Camera ready!" << endl;
> >         //Initialize Shamrock CCD
> >         error = ShamrockInitialize("");
> >         if(error!=SHAMROCK_SUCCESS){
> > ...exiting" <<endl;
> >                 ShutDown();
> >                 return(1);
> >         cout << "Shamrock ready!" << endl;
> >         int nodevices(0);
> >         ShamrockGetNumberDevices(&nodevices);
> >         if(nodevices < 1) {
> >                 cout << "No Shamrock detected...exiting" <<endl;
> >                 ShamrockClose();
> >                 ShutDown();
> >                 return(1);
> > Han anyone had similar issues?
> > Thanks,
> > Hinko
.. the more I see the less I believe.., AE AoR
Re: Andor shamrock not detected Hinko Kocevar
RE: Andor shamrock not detected Mark Rivers
Prev: Re: dbGetLink question Andrew Johnson
Next: EPICS 7 Release Candidate 1 Andrew Johnson
Prev: RE: Andor shamrock not detected Mark Rivers
Next: Re: Andor shamrock not detected Hinko Kocevar
