If you set the EPICS_CA_ADDR_LIST to the broadcast address then you must also set EPICS_CA_AUTO_ADDR_LIST=NO. That is why you are getting these warnings, because these broadcast addresses were already being used because EPICS_CA_AUTO_ADDR_LIST was defaulting to YES.
Warning: Duplicate EPICS CA Address list entry "192.168.1.255:5064" discarded
Warning: Duplicate EPICS CA Address list entry "130.20.49.255:5064" discarded
> -----Original Message-----
> From: Church, Eric D [mailto:[email protected]]
> Sent: Tuesday, December 05, 2017 4:06 PM
> To: Mark Rivers; 'Kasemir, Kay'; Ralph Lange; EPICS Tech Talk
> Cc: Mendez, Jennifer M
> Subject: Re: caget() from C++
> I attach a file showing my efforts at setting this variable in the xterm session in which I run
> my caxyz commands and the record of my puzzling problems. Before trying to export these
> values of EPICS_CA_ADDR_LIST, all was well. Whereas, after setting it, failingx2, if I
> unset it I can not connect: I am not returning to successful camonitoring of just even one
> IOC.
> Note: all the relevant-looking complaints from my 2nd IOC terminal in the attached file ….
> - Eric
> On 12/5/17, 1:43 PM, "Mark Rivers" <[email protected]> wrote:
> > Looks like the EPICS_CA_ADDR_LIST used by camonitor is not using the broadcast
> address of your host.
> It should be doing that automatically without you needing to set
> EPICS_CA_ADDR_LIST. Can you send the output of the following commands Linux
> command in the shell where you are running camonitor.
> ifconfig
> printenv | grep EPICS
> At the IOC shell prompt on both the first and second IOCs send the output of
> epicsPrtEnvParams
> What happens if you set EPICS_CA_ADDR_LIST manually to the broadcast address of
> your system? For example on my system ifconfig shows:
> p5p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
> inet 164.54.160.82 netmask 255.255.255.0 broadcast 164.54.160.255
> inet6 fe80::3efd:feff:fea3:f258 prefixlen 64 scopeid 0x20<link>
> ether 3c:fd:fe:a3:f2:58 txqueuelen 1000 (Ethernet)
> RX packets 80276465019 bytes 92598173910474 (84.2 TiB)
> RX errors 0 dropped 114 overruns 0 frame 0
> TX packets 32261858165 bytes 16671972218313 (15.1 TiB)
> TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
> So I would set EPICS_CA_ADDR_LIST=164.54.160.255
> Mark
> > From: Kasemir, Kay [mailto:[email protected]]
> > Sent: Tuesday, December 05, 2017 3:37 PM
> > To: Church, Eric D; Mark Rivers; Ralph Lange; EPICS Tech Talk
> > >Indeed camonitor can properly watch a channel on the first IOC when only it is
> running. I
> > can dial up and down the voltage from CSS on a particular PV on this first IOC and
> watch
> > it move on camonitor. >When I start the second IOC I can continue this exercise on
> POVs
> > on the first IOC. If I kill camonitor, per your suggestion, I can not start it again on a PV
> on
> > the first IOC. And if I kill the second IOC I can >once again start camonitor
> successfully on
> > a PV on the first IOC.
> > >What does it mean, do ya think?
- Re: caget() from C++ Church, Eric D
- caget() from C++ Church, Eric D
- Re: caget() from C++ Andrew Johnson
- Re: caget() from C++ Mark Rivers
- RE: caget() from C++ Mark Rivers
- Re: caget() from C++ Ralph Lange
- Re: caget() from C++ Kasemir, Kay
RE: EPICS 7 Release Candidate 1 Mark Engbretson
RE: Help needed on adl to opi standalone converter Mark Rivers
<2017>
2025
<2017>
2025
