The syntax for the /std option is documented here
https://docs.microsoft.com/en-us/cpp/build/reference/std-specify-language-standard-version
/std:[c++14|c++17|c++latest]
However this /std compiler flag appears to only be supported in VS 2017. It is not listed in the compiler options for VS2015 here:
https://msdn.microsoft.com/en-us/library/fwkeyyhe.aspx
and generates the following error on VS2015:
cl : Command line warning D9002 : ignoring unknown option '/std:c++14'
So this will not fix the problem in VS2013 or VS2015.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Michael Davidsaver
> Sent: Tuesday, December 05, 2017 9:08 PM
> To: Peterson, Kevin M.; Johnson, Andrew N.; EPICS tech-talk
> Subject: Re: EPICS 7 Release Candidate 1
> On 12/05/2017 03:17 PM, Peterson, Kevin M. wrote:
> > d:\epics7\base-7.0.1-rc1\modules\pva2pva\pdbapp\pdbgroup.h(136): note: see declaration
> of 'PDBGroupChannel'
> > ../pdb.cpp(61): error C2664:
> 'std::shared_ptr<PVIFBuilder>::shared_ptr(std::shared_ptr<PVIFBuilder> &&) noexcept':
> cannot convert argument 1 from 'std::auto_ptr
> > <PVIFBuilder>' to 'std::auto_ptr<PVIFBuilder> &&'
> hmm, seems like that MSVC implementation of shared_ptr doesn't have all of the
> constructor overloads.
> Maybe they've just jumped the gun by removing the deprecated (in c++17) form, even when
> building in c++98?
> http://en.cppreference.com/w/cpp/memory/shared_ptr/shared_ptr
> Can you try to rebuild everything in >= c++11 mode by adding the "/std" compiler flag?
> When built with >= c++11 compatibility, unique_ptr is used instead of (deprecated)
> auto_ptr here.
> https://msdn.microsoft.com/en-us/library/mt490614.aspx
- EPICS 7 Release Candidate 1 Andrew Johnson
- Re: EPICS 7 Release Candidate 1 Peterson, Kevin M.
- Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Re: caget() from C++ Mark Rivers
How to configure and build ca2aa for converting files from Channel Archiver to Archiver Appliance Wang, Lin
<2017>
2025
Re: EPICS 7 Release Candidate 1 Mark Rivers
<2017>
2025
