Subject: Re: Andor Shamrock ShamrockGetCalibration failure
Date: Tue, 12 Dec 2017 15:59:45 +0100
FYI, I had to do some funky business with getting Shamrock to talk to
PC on Linux. I've made a note in the ADAndor documentation and have
contacted Andor to see what they think about that.
/hinko
On Tue, Dec 12, 2017 at 3:56 PM, Hinko Kocevar <[email protected]> wrote:
> Here it is: https://github.com/areaDetector/ADAndor/pull/14
> On Tue, Dec 12, 2017 at 2:43 PM, Mark Rivers <[email protected]> wrote:
>>> I can make a pull request on Github.
>> That sounds good, thanks.
>> ________________________________
>> From: [email protected] <[email protected]> on behalf of Hinko Kocevar <[email protected]>
>> Sent: Tuesday, December 12, 2017 6:42 AM
>> To: [email protected]
>> Subject: Andor Shamrock ShamrockGetCalibration failure
>> Hi,
>> I'm using latest Andor SDK (2.102.30034.0) with Newton 920 and Shamrock 500i.
>> I'm trying to work with Github master branch of ADAndor, ADCore is 3-1.
>> I get these error massages at IOC startup:
>> # Comment out the following lines if there is no Shamrock spectrograph
>> #shamrockConfig(const char *portName, int shamrockId, const char
>> *iniPath, int priority, int stackSize)
>> shamrockConfig("SR1", 0, "", 0, 0)
>> HK: number of pixels: 0
>> HK: pixel width: 0.000000
>> 2017/12/12 11:13:55.196 shamrock:getStatus: ERROR calling
>> ShamrockGetCalibration Description=PARAMETER 3 INVALID
>> dbLoadRecords("/data/shi/R3.15.4/modules/adandor-D1/db/shamrock.template",
>>   "P=13ANDOR1:,R=sham1:,PORT=SR1,TIMEOUT=1,PIXELS=1024")
>> In shamrock.cpp, I added printouts for number of pixels and pixel
>> width since ShamrockGetCalibration() complains that parameter 3 is
>> invalid - 0. Should be 1024.
>> Looking at example console app from Andor, this is how the number of
>> pixels is set up, after camera and spectrograph were detected:
>> //Get Detector dimensions
>> GetDetector(&width, &height);
>> //Sets the number of pixels for calibration purposes
>> ShamrockSetNumberPixels(0, width);
>> float xSize, ySize;
>> //Get Detector pixel size
>> GetPixelSize(&xSize, &ySize);
>> //Set the pixel width in microns for calibration purposes.
>> ShamrockSetPixelWidth(0, xSize);
>> Adding similar lines to shamrock.cpp constructor solves it for me.
>> I tried with 100.30044.0 and I got the same ShamrockGetCalibration()
>> error in the IOC.
>> I have not tried with older Andor SDK.
>> Thanks,
>> Hinko
>> .. the more I see the less I believe.., AE AoR
Andor Shamrock ShamrockGetCalibration failure Hinko Kocevar
Re: Andor Shamrock ShamrockGetCalibration failure Mark Rivers
Re: Andor Shamrock ShamrockGetCalibration failure Hinko Kocevar
Prev: Re: Andor Shamrock ShamrockGetCalibration failure Hinko Kocevar
Next: Area Detector Destructors Mark Engbretson
