Subject: Re: Event triggers for plusers not detected (mrf-timing system)
To: Karim Laihem <[email protected]>
Date: Wed, 13 Dec 2017 18:50:56 +0000
On second thought, I may see a problem after all…
On Dec 11, 2017, at 12:15 AM, Karim Laihem <[email protected]> wrote:
mrf-TEST-EVG0:TrigEvt4-Enable-RB Enabled
mrf-TEST-EVG0:TrigEvt4-EvtCode-RB 0
It looks like you are using trigger 4 to send the event, but the event code you are “sending” is 0 — which is the “null” event.  I think it should be set to “4” if you want the EVR to see an event 4.
-Bj
Event triggers for plusers not detected (mrf-timing system) Karim Laihem
Prev: Re: Event triggers for plusers not detected (mrf-timing system) Bjorklund, Eric A
Next: modbus: problem on readInt32Array Davide Marcato
Next: How to migrate old data from channel archiver to archiver appliance Heinz Junkes
