Subject: Re: Puzzled with lockset(?) problem
To: Michael Davidsaver <[email protected]>, EPICS <[email protected]>, "Mooney, Tim M." <[email protected]>
Date: Tue, 19 Dec 2017 16:43:58 +0100
On 18.12.2017 19:34, Mooney, Tim M. wrote:
 I don't understand what's happening, but I have a clue:  If you write to "mode" directly from an aSub output link, the database behaves as it should.
Interesting.
Also if I scan the aSub directly rather than with a monitor it works as expected. BTW: Making the links from and to the mode record CA (and thus breaking up the locksets) does not help.
On 19.12.2017 00:46, Michael Davidsaver wrote:
Needless to say, my first advice is to be careful about using seqRecord in a loop!
Or any records in a loop. :-)
Thanks for your replies.
I rather wrote the code to make the record asynchronous (when in re-initialization mode). That works well and also does not illegally delay record processing.
Dirk
Puzzled with lockset(?) problem Dirk Zimoch
Re: Puzzled with lockset(?) problem Michael Davidsaver
Prev: Re: Channel Archiver compilation error Heinz Junkes
Next: VisualDCT not starting on RHEL7 Ralph Lange
Prev: Re: Puzzled with lockset(?) problem Michael Davidsaver
Next: EPICS Releases (two!) Andrew Johnson
