1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build pvaPy for Python 3
To: <[email protected]>
Date: Fri, 5 Jan 2018 10:16:01 -0600
Using EPICS7 release should result in a better performance, but since it just came out last month, you might see some issues that have not been caught/fixed yet. In either case, pvaPy maintains backwards compatibility, so if you develop your python application with 4.6.0 v4 release, and later decide to go with epics7, you should not have to change your python code.
Sinisa
On 1/5/18 9:03 AM, renato sanhueza wrote:
I am currently using the EPICS 4.6.0 tar.gz because I thought that EPCIS 7.0 is not stable yet. Am I right?. I will try your solutions now. Thanks!
On Fri, Jan 5, 2018 at 10:30 AM, Siniša Veseli <[email protected]> wrote:
In the tools/build directory there are example scripts for building pvapy, boost, etc. There you will find example scripts for python 3 as well. Basically, if you want to build using automated configuration, you need to use PYTHON_VERSION=3 on the "make configure" line (as outlined in the README.md file).
If you have any issues, let me know.
Sinisa
On 1/5/18 2:03 AM, Ralph Lange wrote:
Hi Renato,
Did you see the recently released 1.0.0 version of pvaPy that includes build support for Python3?
Cheers,
~Ralph
On Fri, Jan 5, 2018 at 5:48 AM, renato sanhueza <[email protected]l> wrote:
I was able to build pvaPy and use it in some examples successfully. The problem is that I also need to use some Python 3 modules. How can I build pvaPy for Python 3.6?
Best regards,
Renato
Renato Sanhueza Ulsen
Ing Civil Informática.
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
[email protected]
(630)252-9182
Siniša Veseli
[email protected]
(630)252-9182
Build pvaPy for Python 3 renato sanhueza
Re: Build pvaPy for Python 3 Ralph Lange
Re: Build pvaPy for Python 3 Siniša Veseli
Re: Build pvaPy for Python 3 renato sanhueza
Prev: VisualDCT 2.7.0 released (for Base 3.16 and EPICS 7) Ralph Lange
Next: Re: void return value in RPC Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build pvaPy for Python 3 renato sanhueza
Next: Re: Build pvaPy for Python 3 renato sanhueza
ANJ, 05 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
