1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request]
To: [email protected]
Date: Mon, 15 Jan 2018 17:13:06 +0900
Dear all,
Last april I posted to teck-talk an problem that cagateway runs away
on rare occasions ( https://epics.anl.gov/tech-talk/2017/msg00714.php
).I successfully reproduced the problem by UDP-port scan with nmap.
When I run nmap as following:
nmap -sU -p 5064 -A ip.address.of.cagateway
- all PVs subscribing via cagateway become disconnected,
- cagateway is eating up the CPU,
- no distinguishable log messege, no "zero length PV name in UDP
search request?" either,
- excas shows the same simptom.
There is no way to exiting the the wile() loop in
casDGClient::processDG() when program reaches at the end of while()
block with a condition such that:
- this->in.bytesPresent()>0 && dgInBytesConsumed == 0 && status ==
S_cas_success.
We are using base R3.14.12.3 for production and R3.15.5 for evaluation
at our site and both have the problem. Also R3.14.12.7 and R3.16.1
seem to have the same problem. Please find a naiive fix for this in
the attatchment.
best regards,
Shuei
                 Shuei Yamada,
                 High Energy Accelerator Research Organization (KEK)
                 mailto:[email protected]
Attachment: casDGClient.patch
Description: Binary data
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
Prev: Latest version of adl2edl Mark Rivers
Next: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Latest version of adl2edl Mark Rivers
ANJ, 16 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
