1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Seq-2.2.5 compilation on windows
To: "Ralph Lange" <[email protected]>
Date: 22 Jan 2018 09:00:08 -0000
Sorry,
   My mistake.
I had re2c 0.9.4, it didn't work.
I used re2c 0.13.5, as suggested by Mark. Now i can compile successfully.
With regards
Vishnu
Sent: Sun, 21 Jan 2018 22:34:30
To: EPICS Tech Talk <[email protected]>
On the installation notes for the sequencer (http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html), Ben has noted that re2c 0.9.9 is the minimum version required, so the documentation is fine.
@Ben: is there an easy way to add a check to the SNL build that would give a more obvious indication?
As always, thanks a lot for your help, Mark!
~Ralph
On Sun, Jan 21, 2018 at 5:41 PM, Vishnu Patel <[email protected]> wrote:
Hi Mark,
   Thanks
   I had re2c 0.9.4 in my system.
Thanks
Vishnu
Sent: Sun, 21 Jan 2018 02:46:59
To: Vishnu Patel <[email protected]>
Cc: techtalk <[email protected]>
Note that re2c 0.13.5 is quite old (2008), but it works fine.  It was the most recent pre-built version I could find for Windows, here:
https://sourceforge.net/projects/re2c/files/old/
Prev: Re: Support for OPC or OPCUA Torsten Bögershausen
Next: RE: Support for OPC or OPCUA Antal, Szabolcs
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Support for OPC or OPCUA Ralph Lange
Next: How to work with motor record position counts larger than 2147483648? Sobhani, Bayan
ANJ, 22 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
