1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using EPICS PV Gateway with multiple IOCs on the same server
To: "Martin L. Smith" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 30 Jan 2018 13:28:55 +0000
Hello Marty
Thank you very much. It works smoothly now.
Best Regards,
Abdalla.
-----Original Message-----
Sent: Tuesday, January 30, 2018 2:46 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
Subject: Re: Using EPICS PV Gateway with multiple IOCs on the same server
Hi Abdalla,
Have you looked at the following wiki page:
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
I think that this will help you.
Marty
On 01/30/2018 03:06 AM, Abdalla  Ahmad wrote:
> Hi
> We installed the CA gateway on a server with only EPICS_CA_ADDR_LIST
> configured in the .bashrc , this server is on a VLAN that can see the
> machine and beamline network. We have on the beamline network a server
> that has multiple IOCs running. This server's IP is used in the
> EPICS_CA_ADDR_LIST on the gateway server, but we can't see the
> beamline PVs, so I turned off all IOCs and ran one IOCs and it works
> fine. Seems the problem is due to the dynamically assigned UDP port because of multiple IOCs.
> I figured out that it is possible to specify the port each IOC uses
> with EPICS_CAS_SERVER_PORT variable on the IOC server, the question
> is, is it possible for the CA gateway to see all these custom
> configured ports? IP routing maybe through the OS?
> Best Regards,
> Abdalla Ahmad
> Control Engineer
> SESAME
> Allan, Jordan.
> Tel: (+962-5) 3511348 , ext. 265
> Fax: (+962-5) 3511423
> Mob: (+962-7)88183296
> www.sesame.org.jo <http://www.sesame.org.jo/>
Using EPICS PV Gateway with multiple IOCs on the same server Abdalla Ahmad
Re: Using EPICS PV Gateway with multiple IOCs on the same server Martin L. Smith
Prev: Re: Using EPICS PV Gateway with multiple IOCs on the same server Martin L. Smith
Next: Scanning on event number fails with EPICS 3.16 Simon Reiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
