1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New releases of areaDetector drivers ADPilatus, ADAndor, ADPerkinElmer, ADLightField, ADPointGrey, ADSimDetector, ADProsilica
To: 'EPICS Mailing list' <[email protected]>
Date: Wed, 31 Jan 2018 19:20:37 +0000
Folks,
New releases of the following areaDetector modules are now available.
ADPilatus
R2-5 (28-January-2018)
* Added support for the ResetModulePower command in camserver 7.9.0 and higher.
  This is important for CdTe detectors where the high-voltage needs to be cycled from
  time to time, particularly after strong saturation of pixels.
* Fixed the parsing of the camserver "Version" command for new versions of camserver
  where it no longer contains the string "tvx-".
* Fixed the parsing of the camserver "Thread" command to read the temperature and
  relative humdidity.  Recent camserver versions do not always return "Channel 0:",
  and this prevented it from working correctly.
* Fixed medm adl files to improve the autoconversion to other display manager files.
* Added op/Makefile to automatically convert adl files to edl, ui, and opi files.
* Updated the edl, ui, and opi autoconvert directories to contain the conversions
  from the most recent adl files.
ADAndor
R2-7 (January 31, 2018)
* Added support for Frame Transfer mode.  Thanks to Michael Dunning for this.
* Added support for setting the Vertical Shift Period. Thanks to Michael Dunning for this.
* Upgraded the Andor SDK version used to 2.102.3 on Linux. Thanks to Hinko Kocevar for this.
ADPerkinElmer
R2-7 (31-January-2018)
* Removed calls to release lock around calls to doCallbacksGenericPointer.
ADLightField
R2-5 (30-January-2018)
* Added support for creating the directories for data and background files.
* LightField.template
  - Change LFGratingWavelength records to LFGratingWL because names were too long for links.
  - Disable PINI for LFGratingWL because it will crash LightField if Step and Glue is enabled.
* Added support for Step And Glue to collect spectra that require changing gratings automatically.
  There are records to enable Step And Glue and to set the starting and ending wavelength.
* Added support for selecting the Entrance Port of the spectrometer.
* Updated the DLL files to those from LightField 6.4.
* Changed CONFIG_SITE to disable GraphicsMagick with LightField because it is incompatible for some reason.
ADPointGrey
R2-6 (29-January-2017)
* Removed the SerialNumber, FirmwareVersion, and SoftwareVersion parameters and records,
  since the equivalents are now in ADDriver.h and ADBase.template.
* Removed code that released the lock around the calls to doCallbacksGenericPointer.
  This was not needed and could cause problems.
ADSimDetector
R2-7 (January 28, 2018)
* Fixed simDetectorNoIOCApp/src/Makefile so it handles external locations of HDF, SZIP, and XML2 correctly.
* Add simDetectorApp/op/Makefile to automatically convert adl files to edl, ui, and opi.
ADProsilica
R2-4 (31-January-2018)
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Next: Re: Suggest EPICS Base series type definitions on website J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Suggest EPICS Base series type definitions on website Andrew Johnson
Next: quadEM R9-1 now available Mark Rivers
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
