1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Re: Segmentation fault when setting motorStatusProblem_ to 1
To: "Sobhani, Bayan" <[email protected]>
Date: Thu, 1 Feb 2018 18:49:06 +0000
>How exactly do i run the IOC from gdb?
# Go to the directory that has the st.cmd file
cd iocStart/your_ioc_directory
# Check the st.cmd file. It should start with something like
#  "#!../../bin/linuxx86_64/name_of_your_ioc_binary"
# That's what you load into GDB
gdb ../../bin/linuxx86_64/name_of_your_ioc_binary
# Then, inside gdb, you start the process with the st.cmd file as input
run st.cmd
# Once it crashes, list the threads
info threads
# Pick one
thread 3
# Get backtrace
bt
# Select some interesting stack frame
frame 2
# print stuff
print some_var
print *some_pointer_var
RE: Segmentation fault when setting motorStatusProblem_ to 1 Sobhani, Bayan
RE: Segmentation fault when setting motorStatusProblem_ to 1 Mark Rivers
Prev: RE: Segmentation fault when setting motorStatusProblem_ to 1 Mark Rivers
Next: RE: Segmentation fault when setting motorStatusProblem_ to 1 Sobhani, Bayan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
ANJ, 01 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
