1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Matlab crash with labCA 3.5.1
To: <[email protected]>
Date: Mon, 12 Feb 2018 12:37:48 -0800
Kiman,
The problem is that mathworks changed some of their mex functions in 2017b, making them incompatible with all but the most recent version of labCA.  In order to fix a previous incompatibility somewhere between epics, matlab, windows, etc., a line was inserted for matlab,
mexLock();
around line 280 in ini.cc, located in the glue subdirectory. r2017b changed the way that mexLock is called.  This caused matlab to crash in both linux and windows.  This is the probable cause for the error you have encountered.  Till found that if we commented out the call to mexLock he was able to get labCA to work in linux.  I repeated the experiment in windows7 and was able to get labCA to work there as well. We made this change in our production systems, both linux and windows, about a month ago and have seen no errors since.
I think that Till has very recently updated his labCA archive to reflect this change, so the most recent version probably does not have this problem.
/afs/slac/g/cd/swe/git/repos/package/epics/extensions/labca.git
But I would first try to just comment out mexLock();, rebuild labCA, and see if your problem is solved.
Jim
Prev: RE: PMAC asyn autoconnect issue Mark Rivers
Next: NSLS-II Debian Repository in 2018 Anton Derbenev
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Matlab crash with labCA 3.5.1 Ha, Kiman
ANJ, 12 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
