1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Autosave -- debug output when field is updated
Date: Tue, 13 Feb 2018 18:50:03 +0000
Hello,
Apologies in advance if this is in the documentation somewhere, I was unable to find it.
We have an IOC which uses quite a lot of CPU when autosave is turned on. This is most likely the result of some inadvertently autosaved fields being updated at 100Hz. Is there a straightforward way, such as an IOC shell command, to print some debug output whenever an autosaved field is written?
Best,
Evan
Re: Autosave -- debug output when field is updated Mooney, Tim M.
RE: Autosave -- debug output when field is updated Mark Rivers
Prev: Re: SMA100A Signal Generatordriver montis
Next: Re: Autosave -- debug output when field is updated Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SMA100A Signal Generatordriver Benjamin Franksen
ANJ, 09 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
