1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: calc support compilation
To: "techtalk" <[email protected]>
Date: 22 Feb 2018 05:06:15 -0000
While compiling calc-3.6.1 from synApps_5_8. i am getting below error
../sseqRecord.c:145:1: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
 epicsExportAddress(rset, sseqRSET);
In file included from ../../../../../../base-3.16.1/include/dbBase.h:21:0,
                 from ../../../../../../base-3.16.1/include/dbAccess.h:19,
                 from ../sseqRecord.c:40:
../../../../../../base-3.16.1/include/recSup.h:67:8: note: declared here
 struct rset { /* record support entry table */
../sseqRecord.c: In function ‘processNextLink’:
../sseqRecord.c:414:13: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
   (*(struct rset *)(pR->rset)).process(pR);
../sseqRecord.c: In function ‘putCallbackCB’:
../sseqRecord.c:536:42: error: ‘struct pv_link’ has no member named ‘precord’
  pR = (sseqRecord *)(plink->value.pv_link.precord);
../sseqRecord.c:563:14: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
../sseqRecord.c: In function ‘processCallback’:
../sseqRecord.c:619:13: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
../sseqRecord.c:604:18: warning: variable ‘did_putCallback’ set but not used [-Wunused-but-set-variable]
  int     status, did_putCallback=0;
../../../../../../base-3.16.1/configure/RULES_BUILD:230: recipe for target 'sseqRecord.o' failed
make[3]: *** [sseqRecord.o] Error 1
make[3]: Leaving directory '/home/dacda/epics/modules/support/calc-3.6.1/calcApp/src/O.linux-x86_64'
../../../../../base-3.16.1/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/dacda/epics/modules/support/calc-3.6.1/calcApp/src'
../../../../base-3.16.1/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
../../../base-3.16.1/configure/RULES_DIRS:84: recipe for target 'calcApp.install' failed
make: *** [calcApp.install] Error 2
I already compiled sscan-2-10-1.
Thanks
Vishnu
Re: calc support compilation Mark Rivers
Prev: Teledyne Lecroy WaveStation 2000/3000 EPICS support Jeong Han Lee
Next: Re: calc support compilation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 22 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
