Manually reconnecting using the asyn record GUI did not work. The Shell yields:
2018/02/26 09:58:54.559 _TEST-RF-DCU-N0001:asyn: queueRequest failed
2018/02/26 09:59:00.162 _TEST-RF-DCU-N0001:asyn: special queueRequest timeout
-----Original Message-----
Sent: Friday, February 23, 2018 3:33 PM
To: Daykin, Evan <[email protected]>
Cc: [email protected]
Subject: Re: Asyn not automatically reconnecting
I am not familiar with this. Can you show me where to find that?
There is an medm screen for the asyn record in asyn. On the master branch there is also a CSS screen I think. The CNCT field let's you manually connect/disconnect. You can do this with caput as well. Look at the asyn record documentation.
Sent from my iPhone
On Feb 23, 2018, at 2:13 PM, Daykin, Evan <[email protected]<mailto:[email protected]>> wrote:
When your client shuts down it does so "cleanly", closing the socket? It looks like it, since drvAsynIPPort detected the closed connection immediately, without first getting any timeouts, etc.
Yes, I just verified this with wireshark. The TCP connection is closed gracefully. Netstat on both ends shows there is no connection as well.
When the client comes back up do you see any different messages?
No, the "...read." message just repeats extremely quickly.
When the client comes back up you can trying using the asynRecord GUI to try to manually reconnect. Does that work?
Something else interesting is that rebooting results in the correct behavior; the connection is re-established. However, if the controlling process on the client device is killed first, this issue persists.
-Evan
Sent: Friday, February 23, 2018 10:49 AM
To: Daykin, Evan <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]>
Hi Evan,
From: Daykin, Evan <[email protected]<mailto:[email protected]>>
Sent: Friday, February 23, 2018 8:55 AM
To: Mark Rivers; [email protected]<mailto:[email protected]>
Subject: RE: Asyn not automatically reconnecting
Here is the output from the moment I killed the connection:
2018/02/23 09:51:47.086 TEST-RF-DCU-N0001 read
VALUE AMP_WATER_FLOW AMP 2 7.0049e-168\n
2018/02/23 09:51:47.087 TEST-RF-DCU-N0001 set Eos 0
2018/02/23 09:51:47.087 asynManager::portThread port=TEST-RF-DCU-N0001 callback
2018/02/23 09:51:47.087 TEST-RF-DCU-N0001 addr -1 queueRequest priority 0 not lockHolder
2018/02/23 09:51:47.088 TEST-RF-DCU-N0001 schedule queueRequest timeout
2018/02/23 09:51:47.088 asynManager::portThread port=TEST-RF-DCU-N0001 callback
2018/02/23 09:51:47.088 test-rf-dcu-n0001.cts:5001 read.
2018/02/23 09:51:47.088 test-rf-dcu-n0001.cts:5001 read 0
2018/02/23 09:51:47.088 Close test-rf-dcu-n0001.cts:5001 connection (fd 18): Read from broken connection
2018/02/23 09:51:47.088 _TEST-RF-DCU-N0001:asyn: exception 0, asynExceptionConnect
2018/02/23 09:51:47.088 TEST-RF-DCU-N0001 read
2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
The last line then repeats rapidly forever.
Sent: Friday, February 23, 2018 9:20 AM
Can you set the asynTraceIOMask to 2 and the asynTraceMask to 0xff on that port just before you shut down the client?
Sent: Friday, February 23, 2018 8:18 AM
To: Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]>>; [email protected]<mailto:[email protected]><mailto:[email protected]>
Hi Mark,
Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3. The protocol file has a ReplyTimeout of 2000ms.
Sent: Thursday, February 22, 2018 6:20 PM
To: Daykin, Evan <[email protected]<mailto:[email protected]><mailto:[email protected]>>; [email protected]<mailto:[email protected]><mailto:[email protected]>
Hi Evan,
Ø We have client devices that, when remotely updated and rebooted, the IOC does not attempt to reconnect automatically
Ø TEST-RF-DCU-N0001 multiDevice:No canBlock:Yes autoConnect:Yes
Ø enabled:Yes connected:No numberConnects 1
Ø nDevices 0 nQueued 114 blocked:No
The above information says that indeed autoConnect is set to Yes, and it is currently not connected. The 114 entries in the queue seems strange.
What version of asyn and what version of StreamDevice are you using? What you are observing does not seem correct.
What timeouts if any have you specified in your protocol file?
From: [email protected]<mailto:[email protected]><mailto:[email protected]> [mailto:[email protected]] On Behalf Of Daykin, Evan
Sent: Thursday, February 22, 2018 4:32 PM
To: [email protected]<mailto:[email protected]><mailto:[email protected]>
Subject: Asyn not automatically reconnecting
Hello,
Apologies if this has already been asked and answered. We have client devices that, when remotely updated and rebooted, the IOC does not attempt to reconnect automatically. Any records tied to it simply enter a TIMEOUT_ALARM state, and no asyn or StreamDevice error messages are printed. autoConnect is not specified in drvAsynIPPortconfigure, which, according to the documentation, implicitly enables autoConnect/attempting to reconnect every 20 seconds. Does anything else need to be done?
The devices are configured to communicate using Stream Device.
Relevant asyn configuration in the startup script:
-drvAsynIPPortConfigure("TEST-RF-DCU-N0001", "test-rf-dcu-n0001.cts:5001")
asynReport after client is disconnected and brought back up:
asynManagerLock:No synchronousLock:Yes
exceptionActive:No exceptionUsers 2 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
interposeInterfaceList
asynOctet pinterface 0x7f0a07506900 drvPvt 0x6c3720
interfaceList
asynCommon pinterface 0x7f0a07502650 drvPvt 0x6bfe30
asynOption pinterface 0x7f0a07502670 drvPvt 0x6bfe30
asynOctet pinterface 0x6bff50 drvPvt 0x6bfe30
Port test-rf-dcu-n0001.cts:5001: Disconnected
fd: -1
Characters written: 127036
Characters read: 138000
-Evan
- RE: Asyn not automatically reconnecting Mark Rivers
- Asyn not automatically reconnecting Daykin, Evan
- RE: Asyn not automatically reconnecting Daykin, Evan
Redirection question l123173
Re: Redirection question Bruno Martins
<2018>
Re: Asyn not automatically reconnecting Mark Rivers
<2018>
