1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Controling a slit system with 2 hard and 4 soft motorrs
To: Torsten Bögershausen <[email protected]>
Date: Thu, 8 Mar 2018 16:47:57 +0000
Hi Torsten,
Look at this database:
https://github.com/epics-modules/motor/blob/master/motorApp/Db/sumDiff2D.db
You load 2 of these for a 4 blade slit.
We use this for lots of systems where you want to move 2 motors in the same direction and opposite directions. For example 2 moment mirror bender, slit,
Etc.
Sent from my iPhone
On Mar 8, 2018, at 10:40 AM, Torsten Bögershausen <[email protected]<mailto:[email protected]>> wrote:
Hej motorists,
I recently learned about the transform record,
which can be used to control a slit with 2 physical
axes in the way that you can set the values for GAP and
CENTER and the position of the physical blades are
calculated. (Or vice versa)
Does anybody have a super-duper-luxus template file
which uses 4 soft motors together with some calc
and transform records ?
Thanks in advance
/Torsten
Controling a slit system with 2 hard and 4 soft motorrs Torsten Bögershausen
Prev: Controling a slit system with 2 hard and 4 soft motorrs Torsten Bögershausen
Next: RE: Controling a slit system with 2 hard and 4 soft motorrs Goetze, Kurt A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 08 Mar 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
