Does you motor actually have an encoder? If not don't worry about ERES or UEIP, and just set MRES to 1/(steps per engineering unit).
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Kevin Peterson
> Sent: Thursday, March 15, 2018 11:43 AM
> To: Sobhani, Bayan <[email protected]>; [email protected]
> Subject: Re: Motor Record not moving distances less than .5
> My replies are below.
> On 03/15/2018 09:59 AM, Sobhani, Bayan wrote:
> > UEIP, MRES, and ERES were:
> > UEIP: "No"
> > MRES: 1
> > ERES: 1
> With this configuration you will be unable to make any move smaller than
> 1, since that is the value of MRES.
> > If I try setting UEIP to "Yes", it does not get set and the value remains "No". If I try
> setting ERES to .1, and then setting UEIP to "Yes", I get the following error message:
> > Illegal choice PV: alexHost:testMotor2.UEIP error detected in routine:
> dbFastLinkConv(cvt_st_menu)
> Some motor controllers don't support encoders, which might result in the
> UEIP value being forced to "No," but that doesn't look like what is
> happening here.
> Which client is being used to change the UEIP value?
> What happens if you do a caput from the command line?
> $ caput alexHost:testMotor2.UEIP "Yes"
> > Alex
> Kevin
- Re: Motor Record not moving distances less than .5 Kevin Peterson
- Motor Record not moving distances less than .5 Sobhani, Bayan
- RE: Motor Record not moving distances less than .5 Sobhani, Bayan
<2018>
<2018>
