1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pushing values to device on (re)connection to IOC
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Fri, 23 Mar 2018 14:57:56 -0500
On 03/23/2018 02:28 PM, Eric Norum wrote:
> Is there a 3.15 version of the record reference manual somewhere?  The
> one I’ve been using
> https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14
> is clearly old.
No, using a wiki didn't work well with multiple parallel releases, and
updating all those tables is almost impossible, so we started converting
those pages into Perl POD format inside the record.dbd file.
We strip off the POD before installing the DBD files, and generate HTML
from the POD and DBD info as part of the Build process (so the tables
get updated automatically). Unfortunately as you'll see if you look in
your base-3.15/html directory though we haven't got terribly far with
the conversion process. Help with this is always welcome, email me!
> My quick attempt at trying the above with the 4 changed to a 5 didn’t
> result in much useful….
Check the release notes for a description of the record-type changes:
    https://epics.anl.gov/base/R3-15/5-docs/RELEASE_NOTES.html
- Andrew
Re: Pushing values to device on (re)connection to IOC Jeong Han Lee
Pushing values to device on (re)connection to IOC Eric Norum
Re: Pushing values to device on (re)connection to IOC Andrew Johnson
Re: Pushing values to device on (re)connection to IOC Eric Norum
Prev: Re: Pushing values to device on (re)connection to IOC Eric Norum
Next: CSDataQuick 1.0 Release Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Pushing values to device on (re)connection to IOC Jeong Han Lee
ANJ, 23 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
