1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Job opening for embedded software engineer at PSI
To: <[email protected]>
Date: Mon, 26 Mar 2018 13:47:42 +0200
1. To all job agencies and similar companies:
We will not accept any applications by agencies if we have to pay for it. Such applications will be ignored. Don't waste your effort.
2. Do not send any applications to the contact person. That contact is for questions about the job. We accept applications *only* through the web form (link on the job opening page). Any application that does not use the web form will be ignored.
Dirk
On 26.03.2018 11:07, Dirk Zimoch wrote:
Hello everyone,
PSI has an open position for a software (EPICS) developer.
Detailed job information can be found here:
https://www.psi.ch/pa/stellenangebote/1730
(In case you don't see anything on that page try to disable content blockers such as uBlock).
Dirk
Job opening for embedded software engineer at PSI Dirk Zimoch
Prev: Job opening for embedded software engineer at PSI Dirk Zimoch
Next: RE: How to start EPICS IOC via LabVIEW on cRIO Baily, Scott A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Nanomotion XCD Series of motor controllers Ronald L. Sluiter
ANJ, 26 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
