1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: PV gateway renders PVs as disconnected
Date: Wed, 28 Mar 2018 11:48:23 +0000
Hi
We are running the gateway on a virtual server with 1 network interface, this server can see all the different LANs (office, machine, beamlines, etc.) through routing rules and access lists done by the IT group. When the gateway is running, after a while entire IOCs gets disconnected. We are running the gateway with no arguments but in the .bashrc file we are defining EPICS_CA_ADDR_LIST having the IP address for the gateway to look at (Not all IOCs). This behavior happened when having all IOCs or some of them in the address list.
I came upon this video from APS https://www.youtube.com/watch?v=Y5Ge89Y4d1E In which, as I understood, they have multiple gateways running on the server with each gateway connects one network interfaces together to the other interfaces. So my questions are:
1.       What is happening with our setup? Some CA loops happens at some point?
2.       Is having a network interface per VLAN optional or recommended?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: PV gateway renders PVs as disconnected Ralph Lange
Re: PV gateway renders PVs as disconnected Paul Sichta
Prev: RE: StreamDevice with Telnet port Abdalla Ahmad
Next: Re: asynMotor: NewFocus 874x Picomotor Controller Driver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Re: asynMotor: NewFocus 874x Picomotor Controller Driver Angelic Ebbers
Next: Re: PV gateway renders PVs as disconnected Ralph Lange
ANJ, 28 Mar 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
