1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: GpibBoardDriverConfig not found
To: "techtalk" <[email protected]>
Date: 9 Apr 2018 11:07:11 -0000
    I am using linux-gpib-4.1.0 to access GPIB devices with Agilent 82357B GPIB-USB adaptor.
With ibtest i can access GPIB instrument without any error.
But making IOC as given in
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_use_GPIB_ports_with_linux-gpib_and_StreamDevice
with LINUX_GPIB=YES in asyn4-33/configure/RELEASE
considering
https://epics.anl.gov/tech-talk/2007/msg01343.php
https://epics.anl.gov/tech-talk/2008/msg00008.php
The gpib library
$ ls /lib/
apparmor/                             klibc-k3La8MUnuzHQ0_kG8hokcGAC0PA.so  systemd/
brltty/                               libgpib.so.0                          sysvinit/
cpp                                   linux-sound-base/                     terminfo/
crda/                                 lsb/                                  udev/
but
$ /sbin/ldconfig -p |grep gpib
doesn't list any gpib library.
But still i am getting and error
## 2 Configure your asynPorts
# 2a GPIB: portname, autoConnect, boardId, timeout, 5th_arg
     GpibBoardDriverConfig("agi", "1", "0", "3", "0")
st.cmd line 18: Command GpibBoardDriverConfig not found.
## Load record instances
dbLoadTemplate "db/user.substitutions"
i am using it on ubuntu 16 with 64 bit machine.
Thanks
Vishnu
Re: GpibBoardDriverConfig not found Mark Rivers
Prev: RE: question about pvAccess monitor [email protected]
Next: Re: Problem with autosave module making it crash at random basis. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with autosave module making it crash at random basis. Konrad, Martin
Next: Re: GpibBoardDriverConfig not found Mark Rivers
ANJ, 26 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
