1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about pvAccess monitor
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>, renato sanhueza <[email protected]>
Date: Mon, 9 Apr 2018 21:03:54 -0700
I'll mention for general interest that another relevant example of solving
this problem is the DBUS system.  A DBUS service has one well known method
"Introspect()" which returns a string (XML) describing all other methods.
https://dbus.freedesktop.org/doc/dbus-specification.html#introspection-format
I'm not advocating adopting this wholesale (and certainly no XML!) but
it is a working example with wide usage in the Linux world.
At some point I'd like to add a scheme like this to the P4P RPC server
helper API, which has access to the information needed to handle this
automatically.
https://mdavidsaver.github.io/p4p/rpc.html
On 04/09/2018 02:17 PM, Andrew Johnson wrote:
> Hi Renato,
> Since EPICS hasn't had native RPC functionality at all before it was
> added in pvAccess, we don't claim to know what the best way might be to
> implement the introspection of RPC interfaces. We could have created a
> standard while writing pvAccess, but we have found in the past that if
> you try to make something generic before you have at least two and
> preferably three or more different examples you often don't make the
> result flexible enough to meet later needs.
> I hope Diamond's "experiment" as Tom called it will help the community
> eventually come up with an "official" approach, assuming of course that
> there is enough demand for a standard that someone is willing to fund
> the development work with either effort or money. If you have specific
> requirements we would be interested in hearing about them.
> Regards,
> - Andrew
> On 04/09/2018 02:13 AM, [email protected] wrote:
>> Hi Renato,
>> That is correct, I would class this as "experiments in how you might do this" rather than "the official way to do this".
>> Thanks,
>> Tom
>>> -----Original Message-----
>>> From: renato sanhueza <[email protected]>
>>> Sent: 08 April 2018 04:47
>>> To: Cobb, Tom (DLSLtd,RAL,TEC) <[email protected]>
>>> Cc: [email protected]
>>> Hi Tom,
>>> Your implementation of dynamic RPC using EPICS is very impressive.
>>> Nonetheless, if I understand correctly, it is not part of the "official" version of
>>> EPICS which I am studying right now.
>>> Thanks for sharing this information,
>>> Renato
>>> On Thu, Apr 5, 2018 at 9:45 AM, [email protected]
>>> <mailto:[email protected]>  <[email protected]
>>> <mailto:[email protected]> > wrote:
>>> 	>       2. Can I use this introspection interface to retrieve the name of a
>>> 	> service and its parameter list to compose a RPC during runtime by
>>> following
>>> 	> Marty's approach?
>>> 	> I suspect that the answer for pvAccess itself is no.
>>> 	> But even if the answer is no a channelRPC service can implement
>>> it's own
>>> 	> query service that describes itself.
>>> 	> But it must describe itself via pvData.
>>> 	That is the approach that Diamond has taken in its continuous
>>> scanning middleware:
>>> 	http://pymalcolm.readthedocs.io/en/latest/reference/structure.ht
>>> ml <http://pymalcolm.readthedocs.io/en/latest/reference/structure.html>
>>> 	We define a Block to be a container for a number of Methods and
>>> Attributes. Attributes are represented by NTScalars, NTScalarArrays and
>>> NTTables, but with their metadata abstracted to separate Meta objects.
>>> These same Meta objects are used to describe the arguments that a Method
>>> should be passed when doing an RPC on it, and the structure it will return.
>>> We implement this in Python, exposing the structures either over pvAccess
>>> (currently with a Diamond specific fork of an old version of pvaPy, but we are
>>> working on this) or as JSON over websockets.
>>> 	Thanks,
>>> 	Tom
>>> 	This e-mail and any attachments may contain confidential, copyright
>>> and or privileged material, and are for the use of the intended addressee
>>> only. If you are not the intended addressee or an authorised recipient of the
>>> addressee please notify us of receipt by returning the e-mail and do not use,
>>> copy, retain, distribute or disclose the information in or attached to the e-
>>> mail.
>>> 	Any opinions expressed within this e-mail are those of the individual
>>> and not necessarily of Diamond Light Source Ltd.
>>> 	Diamond Light Source Ltd. cannot guarantee that this e-mail or any
>>> attachments are free from viruses and we cannot accept liability for any
>>> damage which you may sustain as a result of software viruses which may be
>>> transmitted in or with the message.
>>> 	Diamond Light Source Limited (company no. 4375679). Registered in
>>> England and Wales with its registered office at Diamond House, Harwell
>>> Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
>>> Kingdom
>>> Renato Sanhueza Ulsen
>>> Ing Civil Informática.
question about pvAccess monitor renato sanhueza
Re: question about pvAccess monitor Johnson, Andrew N.
Re: question about pvAccess monitor Mark Rivers
Re: question about pvAccess monitor renato sanhueza
Re: question about pvAccess monitor Marty Kraimer
Re: question about pvAccess monitor Hartman, Steven M.
Re: question about pvAccess monitor Kasemir, Kay
RE: question about pvAccess monitor [email protected]
Re: question about pvAccess monitor Andrew Johnson
Prev: Re: question about pvAccess monitor Andrew Johnson
Next: Re: GpibBoardDriverConfig not found Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Simple channel access write program within Qt Abdalla Ahmad
ANJ, 10 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
