1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GpibBoardDriverConfig not found
To: Vishnu Patel <[email protected]>
Cc: techtalk <[email protected]>
Date: Tue, 10 Apr 2018 11:52:15 +0000
Hi Vishnu,
> This may be because of drvLinuxGpib.dbd doesn't appear in my asyn4-33/dbd even after setting LINUX_GPIB=YES in asyn4-33/configure/RELEASE
You should actually set LINUX_GPIB=YES in configure/CONFIG_SITE, not configure/RELEASE.
I just tested it on my system, I set LINUX_GPIB=YES in configure/CONFIG_SITE.
make[2]: Entering directory `/home/epics/devel/asyn-4-33/asyn/O.linux-x86_64'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86_64/mkmf.pl  -m drvLinuxGpib.d -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/linuxGpib -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/corvette/home/epics/devel/ipac-2-14/include   -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        drvLinuxGpib.o ../../asyn/linuxGpib/drvLinuxGpib.c
make[2]: Leaving directory `/home/epics/devel/asyn-4-33/asyn/O.linux-x86_64'
Installing dbd file ../../dbd/drvLinuxGpib.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/linuxGpib -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/corvette/home/epics/devel/ipac-2-14/include   -I/corvette/home/epics/devel/seq-2-2-5/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -c ../../asyn/linuxGpib/drvLinuxGpib.c
../../asyn/linuxGpib/drvLinuxGpib.c:36:21: fatal error: gpib/ib.h: No such file or directory
 #include <gpib/ib.h>
compilation terminated.
make[2]: *** [drvLinuxGpib.o] Error 1
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/epics/devel/asyn-4-33/asyn'
make: *** [asyn.install] Error 2
corvette:~/devel/asyn>ls -l dbd/*Linux*
-r--r--r-- 1 epics domain users 35 Apr 10 06:44 dbd/drvLinuxGpib.dbd
Note that compilation failed because I don't have the system package for gpib installed (and it does not seem to be available for Centos 7).  But it did install drvLinuxGpib.dbd as it should.  Please set LINUX_GPIB=YES in CONFIG_SITE and let me know if you still have problems.
From: [email protected] <[email protected]> on behalf of Vishnu Patel <[email protected]>
Sent: Tuesday, April 10, 2018 4:03 AM
To: Mark Rivers
Cc: techtalk
Hi Mark,
But after adding drvLinuxGpib.dbd
The IOC compilation gives below error
perl -CSD /opt/epics/base-7.0.1.1/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/opt/epics/support/asyn4-33/dbd -I/opt/epics/support/stream-2-6a//dbd -I/opt/epics/base-7.0.1.1/dbd -o ls218.dbd base.dbd asyn.dbd stream.dbd xxxSupport.dbd dbSubExample.dbd devls218Version.dbd ls218Hello.dbd initTrace.dbd drvLinuxGpib.dbd PVAServerRegister.dbd qsrv.dbd
dbdExpand.pl: Can't find file 'drvLinuxGpib.dbd'
  while reading 'drvLinuxGpib.dbd' to create 'ls218.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/ls218.dbd: $(COMMON_DIR)/drvLinuxGpib.dbd
dbdExpand.pl: Exiting due to errors
/opt/epics/base-7.0.1.1/configure/RULES.Db:402: recipe for target '../O.Common/ls218.dbd' failed
make[3]: *** [../O.Common/ls218.dbd] Error 255
make[3]: Leaving directory '/home/vishnu/epicsDev/ls218/ls218App/src/O.linux-x86_64'
SUPPORT=$(TOP)/../
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
LINUX_GPIB=YES
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
IPAC=$(SUPPORT)/ipac-2-13
# SEQ is required for testIPServer
SNCSEQ=$(SUPPORT)/seq-2.2.5
#  EPICS_BASE 3.14.6 or later is required
EPICS_BASE=$(TOP)/../../base-7.0.1.1
-include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
asyn4-33/dbd$ ls
asyn.dbd                      devAsynRecord.dbd         testAsynPortDriver.dbd
asynRecord.dbd                devAsynUInt32Digital.dbd  testConnect.dbd
devAsynFloat32Array.dbd       devEpics.dbd              test.dbd
devAsynFloat64Array.dbd       devGpib.dbd               testEpics.dbd
devAsynFloat64.dbd            devTestBlock.dbd          testErrors.dbd
devAsynFloat64TimeSeries.dbd  devTestGpib.dbd           testGpib.dbd
devAsynInt16Array.dbd         drvAsynIPPort.dbd         testGpibSerial.dbd
devAsynInt32Array.dbd         drvAsynSerialPort.dbd     testIPServer.dbd
devAsynInt32.dbd              drvGsIP488.dbd            testManager.dbd
devAsynInt32TimeSeries.dbd    drvNi1014.dbd             testOutputCallback.dbd
devAsynInt8Array.dbd          drvVxi11.dbd              testOutputReadback.dbd
devAsynOctet.dbd              testArrayRingBuffer.dbd
May be still i am missing something.
Thank you
Vishnu
Sent: Mon, 09 Apr 2018 17:21:27
To: Vishnu Patel <[email protected]>, techtalk <[email protected]>
Hi Vishnu,
I suspect that your application Makefile is missing a line like this:
myIOCApplication_DBD += drvLinuxGpib.dbd
Or, if you are using an applicationInclude.dbd file then it needs this
include "drvLinuxGpib.dbd"
Sent: Monday, April 9, 2018 6:07 AM
To: techtalk
Subject: GpibBoardDriverConfig not found
   I am using linux-gpib-4.1.0 to access GPIB devices with Agilent 82357B GPIB-USB adaptor.
With ibtest i can access GPIB instrument without any error.
But making IOC as given in
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_use_GPIB_ports_with_linux-gpib_and_StreamDevice
with LINUX_GPIB=YES in asyn4-33/configure/RELEASE
considering
https://epics.anl.gov/tech-talk/2007/msg01343.php
https://epics.anl.gov/tech-talk/2008/msg00008.php
The gpib library
$ ls /lib/
apparmor/                             klibc-k3La8MUnuzHQ0_kG8hokcGAC0PA.so<http://kG8hokcGAC0PA.so>  systemd/
brltty/                               libgpib.so<http://libgpib.so>.0                          sysvinit/
cpp                                   linux-sound-base/                     terminfo/
crda/                                 lsb/                                  udev/
but
$ /sbin/ldconfig -p |grep gpib
doesn't list any gpib library.
But still i am getting and error
## 2 Configure your asynPorts
# 2a GPIB: portname, autoConnect, boardId, timeout, 5th_arg
    GpibBoardDriverConfig("agi", "1", "0", "3", "0")
st.cmd line 18: Command GpibBoardDriverConfig not found.
## Load record instances
dbLoadTemplate "db/user.substitutions"
i am using it on ubuntu 16 with 64 bit machine.
Thanks
Vishnu
Re: GpibBoardDriverConfig not found Mark Rivers
Re: GpibBoardDriverConfig not found Vishnu Patel
Prev: Re: driver support for Gamma Vacuum QPC 4 Martin L. Smith
Next: Re: TeledyneIsco Foxy R2 Fraction Collector [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: GpibBoardDriverConfig not found Vishnu Patel
Next: EPICS CAS errors Oleg A. Makarov
ANJ, 10 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
