1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Which record is the best to use?
To: "Mooney, Tim M." <[email protected]>, "Ivashkevych, Oksana" <[email protected]>, Tech-talk <[email protected]>
Date: Thu, 12 Apr 2018 17:48:49 -1000
You could put in a counter and break out of that loop after a certain
number of tries?
Maren Purves
East Asian Observatory
(I thought I had sent this earlier but got an error)
On 04/11/18 04:40, Mooney, Tim M. wrote:
One way to implement a loop is which a calcout record.  The CALC
expression determines whether or not to loop, and the OOPT field
specifies the condition in which the output link is executed.  The
output link should a CA link, otherwise EPICS will break what looks to
it like an infinite loop.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
behalf of Ivashkevych, Oksana <[email protected]>
*Sent:* Wednesday, April 11, 2018 8:21:46 AM
*To:* Tech-talk
*Subject:* Which record is the best to use?
Hello,
I would like to automate phasing of servomotors in Delta Tau.
1.      Send phasing command via asyn, wait
2.      If Phasing successful(bit x is set), ->DONE
3.      If Phasing error(bit y is set),  do 1 again.
I would like to do it in the database, and not via sequencer, because it
will give me a luxury of using a substitution file and repeating the
same for 9 motors and looks much easier. It would be interesting to see
how Delta Tau will handle several simultaneous phasing requests.
Thank you for your advice.
Oksana
Re: Which record is the best to use? Mooney, Tim M.
Which record is the best to use? Ivashkevych, Oksana
Prev: Re: sscan question Matt Newville
Next: EPICS Record to SCADA data exchange Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Which record is the best to use? Mooney, Tim M.
Next: Re: Which record is the best to use? Mooney, Tim M.
ANJ, 13 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
