1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS xy graph question
To: [email protected]
Date: Wed, 18 Apr 2018 11:31:33 +0200
I have a question regarding the XY graph widget in CS Studio.
I want to define the x axis labels based on an array read from my areadetector
driver. The PV is of type waveform with 4000 elements of type double and
contains one value per bin.  If I put this record as "X PV", the widget shows
an error and the message that the value of this PV is nil.
The reason for this is, that the driver is universal for a class of
spectrometers where every pixel in the sensor stands for a certain wavelength.
Different devices have different ranges of wavelength they cover.
Of course I could hard code the range, but then one needs to generate a
separate OPI file for each type of device.
What is the correct type for the PV that defines the x axis?
Jörn Dreyer
Re: CSS xy graph question Mark Rivers
Prev: Re: areaDetector question Jörn Dreyer
Next: Re: CSS xy graph question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Request for OSI and RTEMS citations Arnold, Ned D.
ANJ, 18 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
