1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base-3.15.5/templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
To: John Dobbins <[email protected]>
Cc: [email protected]
Date: Mon, 23 Apr 2018 10:49:42 -0500
Hi John,
On 04/22/2018 04:08 PM, John Dobbins wrote:
> I am installing EPICS 3.15.5 on a new filesystem, host is scientific
> linux 7.   Downloaded 3.15.5, set EPICS_HOST_ARCH=linux-x86_64, ran make
> to build base.
> Next ran makeBaseApp.pl for an example IOC.
> however envPaths does not appear in iocBoot/iocmyExample when I run make
> in IOC  $(TOP)
Does your Makefile still contain this line?
  TARGETS = envPaths
That's what tells GNUmake to construct that file.
> I see that the Makefile in iocBoot/iocmyExample is missing the line
> ARCH = linux-x86_64
> Upon investigating I see that
> is missing the line
>     ARCH = _ARCH_
> which appears in my previous installations (3.14.12.2).
> 1) should this line still be there (restoring it fixes the problem)
That ARCH variable was explicitly removed from that template file with
this git commit:
> commit 230603f4acf03a8cf147e502626e01a87dae66ce
> Author: Andrew Johnson <[email protected]>
> Date:   Thu Apr 28 18:50:41 2016 -0500
>     Remove ARCH from cdCommands and envPaths files
>     Set it in iocshRegisterCommon() instead.
>     Remove ARCH from iocBoot/ioc/Makefile@Common templates.
It shouldn't be needed any more for Unix-like host targets, the envPaths
file is now architecture-neutral; my RHEL7 box happily creates it both
with and without ARCH being set. The ARCH variable is still needed to
create some of the other iocBoot/ioc files though, such as cdCommands
(used for VxWorks targets) and dllPath (Windows targets).
> 2) if yes, any idea where I went astray?
Not yet. This was from inside my iocBoot/iochost directory created from
the example template:
> tux% make clean
> rm -f cdCommands envPaths dllPath.bat relPaths.sh
> tux% cat Makefile
> TOP = ../..
> include $(TOP)/configure/CONFIG
> TARGETS = envPaths
> include $(TOP)/configure/RULES.ioc
> tux% make
> perl -CSD /home/phoebus/ANJ/epics/base/3.15/bin/linux-x86_64/convertRelease.pl -t /home/phoebus3/ANJ/apps/3.15-example envPaths
> tux% cat envPaths
> epicsEnvSet("IOC","iochost")
> epicsEnvSet("TOP","/home/phoebus3/ANJ/apps/3.15-example")
> epicsEnvSet("EPICS_BASE","/home/phoebus/ANJ/epics/base/3.15")
> tux%
- Andrew
Re: base-3.15.5/templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common John Dobbins
Prev: Re: NSLS-II Debian Repository in 2018 Christoph Schroeder
Next: Re: ADPointGrey with AD3-2, and base-7.0.1.1 Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: base-3.15.5/templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common John Dobbins
Next: Re: base-3.15.5/templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common John Dobbins
ANJ, 23 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
