1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NSLS-II Debian Repository in 2018
To: EPICS Tech Talk <[email protected]>
Date: Fri, 27 Apr 2018 07:48:51 +0000
Well,
While I can enjoy the "...and it does it all by itself!" feature of such a setup, I see development and deployment as two very distinct phases, with a lot of QA inbetween.
Nonetheless: having such a repository of packaged "bleeding edge" development can be very useful. E.g. for an automated building infrastructure that is required to build packages against different supported releases and the current development branches. If the current development is available as packages, it is very easy to automatically update the bleeding-edge builders at the beginning of each job.
(ITER is recreating the "nightly" builders as the result of a successful nightly build, which is somewhat close.)
But for any reference, release or production use, I would always insist on developers signing off on what is being packaged. And reasonable version numbers, of course.
Cheers,
~Ralph
On Fri, Apr 27, 2018 at 1:51 AM Konrad, Martin <[email protected]> wrote:
Hi Anton,
I would like to share how we generate our (a bit crazy) "FRIB version
numbers" that are automatically generated by our CI server. The
numbering scheme is based on the convention used by Jenkins-Debian Glue
[1,2]:
Re: NSLS-II Debian Repository in 2018 Anton Derbenev
Re: NSLS-II Debian Repository in 2018 Ralph Lange
Re: NSLS-II Debian Repository in 2018 Konrad, Martin
Prev: Re: rtems_cpu_usage_report Ralph Lange
Next: Re: rtems_cpu_usage_report Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NSLS-II Debian Repository in 2018 Konrad, Martin
Next: Re: NSLS-II Debian Repository in 2018 Anton Derbenev
ANJ, 30 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
