1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: rtems_cpu_usage_report
To: Talk EPICS Tech <[email protected]>
Date: Fri, 27 Apr 2018 11:37:47 -1000
Hi Andrew,
Thanks, I was not aware about rtemsUtils. I had a quick look at the code and built it into our IOC. It seems more useful than the implementation offered by RTEMS (at least it won't try to display negative values). Having the stack usage added as a freebie is nice, too.
Ricardo
On Fri, Apr 27, 2018 at 5:26 AM, Andrew Johnson <[email protected]> wrote:
On 04/27/2018 02:20 AM, Ralph Lange wrote:
> Nice printout. Is this from the commonly used iocStats module [1]?
This output looks more like an RTEMS version of the VxWorks spy command.
Eric Norum wrote one of those for us many years ago, which is available
in the rtemsUtils module from here:
    https://epics.anl.gov/download/modules/
Eric's version also measures the stack usage of each task.
It might make sense for his code to be moved into the iocStats module.
- Andrew
rtems_cpu_usage_report Matt Rippa
Re: rtems_cpu_usage_report Ralph Lange
Re: rtems_cpu_usage_report Andrew Johnson
Prev: Re: rtems_cpu_usage_report Ricardo Cardenes
Next: Crash in RecDynLink? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: rtems_cpu_usage_report Andrew Johnson
Next: Re: rtems_cpu_usage_report Ricardo Cardenes
ANJ, 29 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
