1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error calling PVUtil.getString()
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 8 May 2018 06:54:36 +0000
Gregory,
you can print into CSS console with:
from org.csstudio.opibuilder.scriptUtil import ConsoleUtil
ConsoleUtil.writeInfo("Hello!")
Luca
On Mon, 2018-05-07 at 21:17 +0000, Lang, Keenan C. wrote:
print(type(pvs[0])) would do it in a normal python script, though I'm not perfectly certain how CSS BOY handles output to stdout.
Sent: Monday, May 7, 2018 3:32:36 PM
To: Lang, Keenan C.; Engbretson, Mark S.; [email protected]
Subject: RE: error calling PVUtil.getString()
I am creating the PVs list in the OPI editor in the ‘Attach Scripts’ dialog. For pvs[0] I have defined it to be ‘$(S):INTYPE$(IN_CHN)_S’ in the ‘Input PVs’ tab of the ‘Attach Scripts’ dialog, where S and IN_CHN are macros.
Can you please tell me how to print pvs[0]'s type in the code?
Thank you for your help,
--Ray
Sent: Monday, May 07, 2018 4:27 PM
To: Gregory, Ray <[email protected]>; Engbretson, Mark S. <[email protected]>; [email protected]
Your error indicates that pvs[0] is a different type of value than the function expects to find.
How are you creating the pvs list? And/or could you print what pvs[0]'s type is right before the command on line 24?
From: [email protected] <[email protected]> on behalf of Gregory, Ray <[email protected]>
Sent: Monday, May 7, 2018 2:22:38 PM
To: Engbretson, Mark S.; [email protected]
caget gives:
$ caget BL104:SE:LS:INTYPE0_SS
BL104:SE:LS:INTYPE0_SS         Platinum RTD
The PV is a mbbo record.
--Ray
Ray Gregory
Data Acquisition and Controls
HFIR Instrument Operations
Instrument and Source Division
Neutron Sciences Directorate
Oak Ridge National Laboratory
Building 7964K Room 19
ph     (865) 241-1116
cell    (417) 827-6515
email:  [email protected]
1 Bethel Valley Road, MS-6430
Oak Ridge, TN               37830
Sent: Monday, May 07, 2018 3:11 PM
To: Gregory, Ray <[email protected]>; [email protected]
What is the value of pvs[0] ?
From: [email protected] <[email protected]> On Behalf Of Gregory, Ray
Sent: Monday, May 7, 2018 2:02 PM
To: [email protected]
Subject: error calling PVUtil.getString()
In a CSS BOY OPI I am calling PVUtil.getString() from a script attached to my OPI. I am passing it one of the script’s PV values:
Line
22           from org.csstudio.opibuilder.scriptUtil import PVUtil, ScriptUtil
23
24           sensor_type = PVUtil.getString(pvs[0])
However I am getting the following error:
Traceback (most recent call last):
  File "scripts/lakeshore_input_setup_monitor.py.py", line 24, in <module>
TypeError: getString(): 1st arg can't be coerced to org.csstudio.simplepv.IPV
What does this mean?
--Ray
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
RE: error calling PVUtil.getString() Gregory, Ray
RE: error calling PVUtil.getString() Mark Engbretson
Re: error calling PVUtil.getString() Lang, Keenan C.
Prev: Re: error calling PVUtil.getString() Lang, Keenan C.
Next: RE: PV gateway renders PVs as disconnected Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: error calling PVUtil.getString() Gregory, Ray
ANJ, 08 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
