I installed the support mca7-7 to use a X-123SDD Detector using the MCA
Amptek Driver. The IOC starts correctly and the medm screen Amptek.adl
works perfectly, but I'm having problem to read a PV mca1.
In the medm screen mca.adl the graph don't show any data and return the
follow message: The requested data transfer is greater than available
memory or EPICS_CA_MAX_ARRAY_BYTES. If I use "caget" in this PV, I have
the same problem.
But, if I limit the number of elements of array until 4095 using: caget
-# 4095 mcaTest:mca1 for example, the pv return a correct value.
I put a very high value in variable
EPICS_CA_MAX_ARRAY_BYTES="999999999999", but it still didn't work.
Has anyone had this kind of problem? Any idea how to debug/solve this?
Best Regards
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1228
www.lnls.br
- Re: MCA7-7: Problems to read PV mca Hugo Slepicka
RE: OPI script and Display Builder Gregory, Ray
<2018>
<2018>
ANJ, 08 May 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
