1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: need an IOC with a wide variety of data types for testing purposes
To: "[email protected]" <[email protected]>, Giacomo S. <[email protected]>
Date: Fri, 11 May 2018 16:26:26 +0000
Hi Giacomo,
you don't even need to code your own IOC. You need only a database to provide all your empty PVs of different types. Than run it with softIOC provided by EPICS base. You can even add some logic inside the db (e.g. calc record) or easier, write some scripts in python, bash, perl or whatever to "move" the PVs. You can then read and monitor them from your CAC. For the database creation the easier option is VisualDCT tool.
Ciao,
Luca
On Fri, May 11, 2018 at 5:28 PM +0200, "Giacomo S." <[email protected]> wrote:
Hello everyone.
After installing EPICS and reading the paragraph: "Build the example
application", generating  and installing the test IOC with:
     makeBaseApp.pl -t example test
I see that the example IOC exports just a few types of data: mainly "ai"
analog input.
I would like to test a client application to read/write waveforms,
strings, arrays of strings, enums and so on..
In other words, is there an example IOC  where I can use ca clients
(camonitor, caput)  to try monitoring and writing several types of data?
As the example obtained with makeBaseApp generates an "ai" changing from
0 to 9, the test example I am looking for should generate changing
waveforms, enums, strings, arrays of strings.
Thanks for any suggestion.
Giacomo. Italy.
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
need an IOC with a wide variety of data types for testing purposes Giacomo S.
Prev: Re: benchtop testbeds for EPICS development and testing? Gedare Bloom
Next: Re: benchtop testbeds for EPICS development and testing? Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: need an IOC with a wide variety of data types for testing purposes Giacomo S.
Next: EPICS training - lecture series Gofron, Kazimierz
ANJ, 11 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
