1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Smaract MCS2 Motor Record
To: "Lentz, Zachary L" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 May 2018 21:58:11 +0000
Very valuable feedback, thank you Zachary. To answer your questions:
1) It believe so. It has been a few months, but I do not remember leaving any feature out. Additionally, it has some useful features which the old MCS motor record does not have, such as limit switch status.
2) At the time I started working on this, only the SDK commands were documented. Later upon request, the vendor provided me a version of the manual with ascii commands, but I was already almost finished by then. Since the logic is already implemented it should be straightforward to translate the SDK motor record to ascii and I may do it in the next 1 or 2 weeks if I have time and no one beats me to it. Some very old versions of the GNU C library cannot compile the files that use the MCS2 SDK.
3) Thanks for pointing this out. I believe it is fixed now.
4) I am not sure it I am high enough caliber for this.
Alex
Sent: Thursday, May 10, 2018 6:18 PM
To: Sobhani, Bayan; [email protected]
Subject: Re: Smaract MCS2 Motor Record
Hi Alex,
This looks promising, thank you for sharing. A couple of questions:
  1.  The old MCS drivers supported a specific subset of MCS and motor record features. Does this support a similar subset?
  2.  Any reason why you opted to link against the MCS2 SDK instead of talking over serial?
  3.  It looks an IP and port is being hard-coded in the driver. Do you plan to generalize this? Are there other things that are hard-coded?
  4.  Do you plan to submit this for the main motor record?
-Zachary
Sent: Thursday, May 10, 2018 6:39:22 AM
To: Lentz, Zachary L; [email protected]
Hi Zachary,
Yes, we have an MCS2 IOC that we have been using without issue for the last few months at NSLS2:
SmarAct MCS2 IOC: https://github.com/bsobhani/smaract-mcs2
SmarAct MCS2 Motor Record: https://github.com/bsobhani/motor-mcs2
So far it has been tested on Debian 8 machines. Let me know if you run into any problems.
Alex
From: [email protected] <[email protected]> On Behalf Of Lentz, Zachary L
Sent: Wednesday, May 9, 2018 6:09 PM
To: [email protected]
Subject: Smaract MCS2 Motor Record
Is anyone developing motor record support for the SmarAct MCS2 controller? It unfortunately has a completely different command set than their previous MCS controller. We're looking to use these for some projects at SLAC.
Zachary Lentz
Re: Smaract MCS2 Motor Record Pete Jemian
Smaract MCS2 Motor Record Lentz, Zachary L
RE: Smaract MCS2 Motor Record Sobhani, Bayan
Re: Smaract MCS2 Motor Record Lentz, Zachary L
Prev: RE: SOLEIL's TimEx3 Goetze, Kurt A.
Next: Re: Smaract MCS2 Motor Record Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Smaract MCS2 Motor Record Lentz, Zachary L
ANJ, 11 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
