1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Problem when compiling devlib2 against EPICS 7
To: Jörn Dreyer <[email protected]>, <[email protected]>
Date: Wed, 16 May 2018 15:44:19 +0200
On 05/16/2018 12:54 PM, Jörn Dreyer wrote:
> I encountered a Problem in the devlib2 code. It does not compile with EPICS7.
> I had to apply this patch to get it compiling:
> diff -Naur EPICS-7.0.1-org/modules/src/devlib2/exploreApp/src/
> devexplore_util.cpp EPICS-7.0.1/modules/src/devlib2/exploreApp/src/
> devexplore_util.cpp
> --- EPICS-7.0.1-org/modules/src/devlib2/exploreApp/src/devexplore_util.cpp
> 2018-05-16 09:12:24.167857218 +0200
> +++ EPICS-7.0.1/modules/src/devlib2/exploreApp/src/devexplore_util.cpp
> 2018-05-16 09:02:52.865400778 +0200
> @@ -5,6 +5,9 @@
>  #include <epicsVersion.h>
>  #include <epicsStdlib.h>
> +#if EPICS_VERSION > 4
> +#include <errlog.h>
> +#endif
The #include here can and should be unconditional.
>  #define epicsExportSharedSymbols
>  #include "devexplore.h"
> @@ -32,7 +35,7 @@
> -#if EPICS_REVISION<=14
> +#if EPICS_VERSION <= 3 && EPICS_REVISION<=14
>  #define M_stdlib 4242
>  #define S_stdlib_noConversion (M_stdlib | 1) /* No digits to convert */
> I used the actual code from github to be sure   not to miss any updates.
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Problem when compiling devlib2 against EPICS 7 Michael Davidsaver
Problem when compiling devlib2 against EPICS 7 Jörn Dreyer
Prev: Problem when compiling devlib2 against EPICS 7 Jörn Dreyer
Next: Re: Thorlabs FW102C Support? Brian Freeman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: Re: Problem when compiling devlib2 against EPICS 7 Michael Davidsaver
ANJ, 16 May 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
