1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: QEgui strip chart question
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 18 May 2018 05:35:58 +0000
Hi Doug,
The number of points store for each live PV data is 40000 points.
This is currently hard coded at that value.
For the next release I can certainly increase this value and/or make
it controllable via an environment variable.
Regards
Andrew C. Starritt | Leader Accelerator and Support Systems | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Thursday, 17 May 2018 8:00 AM
To: [email protected]
Subject: QEgui strip chart question
Hello,
I'm running a test setup for the QEgui tools as a possible replacement for
the EPICS striptool. The strip chart runs perfectly except for one issue.
The data cuts off after a certain amount of time depending on the number
of channels I am plotting. This is only live data haven't tried the
archive look up yet. So for one channel I get about three days of
plotting. For nine channels I get about one and a half hours. I assume
this has to do with a buffer setting somewhere but after days of searching
I have not been able to find it.
Any help would be greatly appreciated.
Thank you in advance,
Doug Lormand
QEgui strip chart question marc . lormand
Prev: Re: Amptek IOC: Problem with subnet Andrew Johnson
Next: EPICS control of an Edwards STP turbomolecular pump Lucock, Richard M
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: QEgui strip chart question marc . lormand
Next: Question regarding asynParamInt32Array Jörn Dreyer
ANJ, 18 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
