1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector 2-5, NDPluginDriver
To: "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 22 May 2018 18:07:13 +0000
Thanks a lot
T
Sent: Tuesday, May 22, 2018 12:41:58 PM
To: Madden, Timothy J.; [email protected]
Subject: RE: AreaDetector 2-5, NDPluginDriver
Hi Tim,
I see you have figured out the problem.  But since I had already composed this message, and it might be useful in the future I am sending it anyway.
Ø  Also, I have seen other plugins like the FFT plugin, that do not call start(), but I assume they work.
Ø  Am I supposed to call start? I have another plugin that only works if I call start.
Yes, your plugin must call start.  What version of ADCore are you using?  The FFT plugin does call start, per this commit from 2 years ago:
commit 73f73ffb5be190d67990ef7a1b4a66bdd436e5f3
Author: Ulrik Kofoed Pedersen <[email protected]>
Date:   Mon Apr 4 22:14:01 2016 +0100
    Calling plugins start method to startup thread
This is the code that calls start in NDPluginFFT.cpp:
/** Configuration command */
extern "C" int NDFFTConfigure(const char *portName, int queueSize, int blockingCallbacks,
                                     const char *NDArrayPort, int NDArrayAddr,
                                     int maxBuffers, size_t maxMemory,
                                     int priority, int stackSize, int maxThreads)
    NDPluginFFT *pPlugin = new NDPluginFFT(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr,
                                           maxBuffers, maxMemory, priority, stackSize, maxThreads);
    return pPlugin->start();
I can think of 3 reasons that your plugin would not be getting callbacks:
1.      You have not called start()
2.      You have not enabled the plugin
3.      You have not correctly set the source port for the plugin to be your driver’s asyn port name.
Ø  Is there a way to ask a driver how may plugins are waiting for NDArrays? Or to list listening plugins with something like asynReport?
You can get that information with asynReport on the driver asyn port if you use details=3 or higher.
epics> asynReport 3 SIM1
    genericPointer callback client address=0x614560, addr=-1, reason=41, userPvt=0x1e77000
    genericPointer callback client address=0x614560, addr=-1, reason=41, userPvt=0x1fafce0
    genericPointer callback client address=0x614560, addr=-1, reason=41, userPvt=0x2103840
    genericPointer callback client address=0x614560, addr=-1, reason=41, userPvt=0x2174360
    genericPointer callback client address=0x614560, addr=-1, reason=41, userPvt=0x21d18d0
This is a list of all the plugins that have registered for callbacks on the genericPointer interface with this driver.  That is the interface that is used for NDArray callbacks.  Unfortunately it does not have address to the port name, just the address in userPvt.  But at least you can see how many plugins have registered for callbacks.
From: [email protected] [mailto:[email protected]] On Behalf Of Madden, Timothy J.
Sent: Tuesday, May 22, 2018 10:49 AM
To: [email protected]
Subject: AreaDetector 2-5, NDPluginDriver
Dear Tech Talkers (or Mark):
I am rather stuck in writing a plugin for AD, even though I have done about 20 of these.
I am inheriting from NDPluginDriver, and the plugin never responds to NDArrays from the driver. The driver is
working OK, as other plugins can get arrays from them.
I call start() in the plugin constructor to start the plugin threads etc.
The IOC console gives on startup:
2018/05/22 10:35:24.570 NDPluginDriver::start timeout waiting for plugin thread start event
So it looks like the plugin is never starting up. Why would this happen? How to debug it?
Very strange. Never seen this one before. I have been hacking on this for awhile.
I stepped through the code with debugger, and I don't think my plugin is in the list of pClients the
driver uses to pass arrays.
Frustrated,
Tim Madden
AreaDetector 2-5, NDPluginDriver Madden, Timothy J.
RE: AreaDetector 2-5, NDPluginDriver Mark Rivers
Prev: RE: AreaDetector 2-5, NDPluginDriver Mark Rivers
Next: :tdir messages in ioc for Pmac Gofron, Kazimierz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Tech-talk Digest, Vol 12, Issue 229 Madden, Timothy J.
ANJ, 22 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
