My turbo pmac motors sometimes get 'stuck', mainly when tweaking them, and particularly when motion direction is reversed. Pressing tweak value several times increases
requested position, but no motion occurs. Pressing 'Kill" results in motion to proceed to the requested position. In the same time, there are ':tdir' messages in the IOC itself:
epics> XF:11IDB-ES{Dif-Ax:Gam}Mtr:tdir = 1
XF:11IDB-ES{Dif-Ax:Gam}Mtr:tdir = 0
XF:11IDB-ES{Dif-Ax:Del}Mtr:tdir = 0
epics> XF:11IDB-ES{Dif-Ax:Del}Mtr:tdir = 0
epics> dbpr XF:11IDB-ES{Dif-Ax:Del}Mtr 4
ACCL: 0.2 ACKS: NO_ALARM ACKT: YES ADEL: 0
ALST: 0 ASG: ASP: (nil) ATHM: 0
BACC: 0.5 BDST: 0 BKPT: 00 BVEL: 0
CARD: 0 CBAK: 0xe81900 CDIR: 1 CNEN: Disable
DCOF: 0 DESC: Delta DHLM: 0
DIFF: -6.5474440000024e-04 DINP:CONSTANT DIR: Pos
DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1
DLLM: 0 DLY: 0 DMOV: 1 DOL:CONSTANT
DPVT: 0xe819a0 DRBV: 2.0006547444 DSET: 0x7f095de16280
DTYP: asynMotor DVAL: 2 EGU: deg ERES: 2.86479e-05
EVNT: 0 FLNK:CONSTANT 0 FOF: 0 FOFF: Variable
FRAC: 1 HHSV: NO_ALARM HIGH: 0 HIHI: 0
HLM: 0 HLS: 0 HLSV: NO_ALARM HOMF: 0
HOMR: 0 HOPR: 0 HSV: NO_ALARM HVEL: 0
ICOF: 0 INIT: JAR: 0 JOGF: 0
JOGR: 0 JVEL: 0 LCNT: 0 LDVL: 2
LLM: 0 LLS: 0 LLSV: NO_ALARM LOCK: NO
LOLO: 0 LOPR: 0 LOW: 0 LRLV: 0
LRVL: 69813 LSET: 0xe88200 LSPG: Go LSV: NO_ALARM
LVAL: 2 LVIO: 0 MDEL: 0 MIP: 0
MLIS: 20 cc 06 54 09 7f 00 00 90 b7 ff 00 00 00 00 00 a7 01 00 00
MLOK: 50 68 df 00 00 00 00 00 MLST: 0 MMAP: 0
MOVN: 0 MRES: 2.86479e-05 MSTA: 2307
NAME: XF:11IDB-ES{Dif-Ax:Del}Mtr NMAP: 0 NSEV: NO_ALARM
NSTA: NO_ALARM NTM: YES NTMF: 2 OFF: 0
OMSL: supervisory OUT:INST_IO @asyn(motor,1) PACT: 0
PCOF: 0 PHAS: 0 PINI: NO POST:
PP: 0 PPN: (nil) PPNR: (nil) PREC: 4
PREM: PRIO: LOW PROC: 0 PUTF: 0
RBV: 2.0006547444 RCNT: 0 RDBD: 2.86479e-05 RDBL:CONSTANT
RDES: 0xc0d9b0 RDIF: -23 REP: 69836 RHLS: 0
RINP:CONSTANT RLLS: 0 RLNK:CONSTANT RLV: 0
RMOD: Default RMP: 69836 RPRO: 0 RRBV: 69836
RRES: 0 RSET: 0x7f095de160a0 RTRY: 0
RVAL: 69813 RVEL: 0 S: 0 SBAK: 0
SBAS: 0 SCAN: Passive SDIS:CONSTANT SET: Use
SEVR: NO_ALARM SMAX: 0 SPMG: Go SPVT: (nil)
SREV: 200 SSET: 0 STAT: NO_ALARM STOO:CONSTANT
STOP: 0 STUP: OFF SUSE: 0 SYNC: 0
TDIR: 1 TIME: 2018-05-22 13:45:45.833378801 TPRO: 0
TSE: 0 TSEL:CONSTANT TWF: 0 TWR: 0
TWV: 0.02 UDF: 0 UEIP: No UREV: 0.00572958
URIP: No VAL: 2 VBAS: 0 VELO: 0
VERS: 6.81 VMAX: 0 VOF: 0
