1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME configuration : MVME6100 can not map slot x to CR/CSR
To: 유진성 <[email protected]>
Cc: [email protected]
Date: Sat, 26 May 2018 18:33:45 -0700
> - linux : 2.6.20
What you see is not a mis-configuration.  Unfortunately there
is no backend for VME on Linux included in devlib2.  Only for
RTEMS or vxWorks.
I know there is at least one implementation out there using a
proprietary Linux driver for a VME bridge (not sure which one).
I've never had access to this.
So your options as I see them are to figure out how to use RTEMS,
or to find/write a Linux driver which devlib2 can be made to use*.
RTEMS is probably the easier route, although as you've found
there is a learning curve.
Michael
* The standard Linux VME userspace module doesn't support interrupts,
  and would need modification/replacement as mrfioc2 relies heavily
  on interrupts.
On 05/25/2018 08:00 AM, 유진성 wrote:
> Hello
> This question is about configuration of VME-EVG-230 or not.
> Before I use mrfioc2 and devLib2, I didn't change configuration of any pins(GAP*, GA*) on VME-EVG-230.
> I'm not sure that I have to change pins(GAP* and GA*) to load VME-EVG-230 on MVME6100(CPU) or not.
> anyways, I made software environment successfully. there were no error during compiling.
> but, I run EPICS IOC. And then I got problem.
> *figure 1. trouble*
> At that time, mrmEvgSetupVME() can't find EVG on my VME Crate.
> I typed the collect CS/CSR starting Address that is based on MVME6100 reference manual.
> *figure 2. CR/CSR slave address for MVME6100*
> I can't find what is problem(software configuration or hardware setting).
> I'm newbie for VME platform. please, check my log and answer me.
> I'll wait for your reply
> best regards,
> P.S
> Software environment, Hardware environment and log are below:
> ======software======
> - linux : 2.6.20
> - BSP : zImage.initrd.6100.2620.rm01 for MVME6100 from EMERSON
> - devLib2 : 2.9
> - epics : 3.14.12-rc1
> - mfrioc2 : 2.2.0
> =====Hardware=====
> - VME crate : VME 64x
> - CPU : MVME6100
> - EVR : VME-EVR-230
> - EVG : VME-EVG-230
> =====log=======
> -bash-3.2# ../../bin/linux-ppc74xx/mrf st.cmd
> #!../../bin/linux-x86/nsls2evgMrm
> < envPaths
> epicsEnvSet("ARCH","linux-ppc74xx")
> epicsEnvSet("IOC","iocevgmrm")
> epicsEnvSet("TOP","/usr/local/epics/base/modules/instrument/mrfioc2-2.2.0/")
> epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
> cd /usr/local/epics/base/modules/instrument/mrfioc2-2.2.0
> ## Register all support components
> #dbLoadDatabase("/usr/local/epics/base/modules/instrument/mrfioc2-2.2.0/dbd/mrf.dbd")
> dbLoadDatabase("dbd/mrf.dbd")
> mrf_registerRecordDeviceDriver(pdbbase)
> Warning: IOC is booting with TOP = "/usr/local/epics/base/modules/instrument/mrfioc2-2.2.0/"
>           but was built with TOP = "/usr/local/epics/R3.14.12-rc1/modules/instrument/mrfioc2-2.2.0"
> epicsEnvSet("ENGINEER","Jayesh Shah")
> epicsEnvSet("LOCATION","Blg 902 Rm 28")
> bspExtVerbosity=0
> st.cmd -- Line 14 -- Command bspExtVerbosity=0 not found.
> #mrmEvgSetupVME (
> #    const char*   id,                // EVG card ID
> #    epicsInt32    slot,              // VME slot
> #    epicsUInt32   vmeAddress,        // Desired VME address in A24 space
> #    epicsInt32    irqLevel           // IRQ Level
> #    epicsInt32    irqVector,         // Desired interrupt vector number
> mrmEvgSetupVME(EVG1, 4, 0x200000, 4, 0xC0)
> pdevLibVME is NULL
> Failed to map slot 4 to CR/CSR address 0x00200000
> No EVG in slot 4
> ## Load record instances
> dbLoadRecords("db/vme-evg230.db", "SYS=TST, D=evg:1, EVG=EVG1")
> # BNL specific timing sequence constructor
> #dbLoadRecords("db/nsls2-inj-seqs.db","LN=LN-TS, BR=BR-TS, INJ=TST, EVG=evg:1, SEQ=SoftSeq:0")
> dbLoadRecords("db/iocAdminRTEMS.db", "IOC=mrftest")
> filename="../dbLexRoutines.c" line number=243
> No such file or directory dbRead opening file db/iocAdminRTEMS.db
> # Auto save/restore
> # save_restoreDebug(2)
> # dbLoadRecords("db/save_restoreStatus.db", "P=mrftest:")
> # save_restoreSet_status_prefix("mrftest:")
> # set_savefile_path("{mnt}/as","/save")
> # set_requestfile_path("{mnt}/as","/req")
> # set_pass0_restoreFile("mrf_settings.sav")
> # set_pass0_restoreFile("mrf_values.sav")
> # set_pass1_restoreFile("mrf_values.sav")
> # set_pass1_restoreFile("mrf_waveforms.sav")
> iocInit()
> Starting iocInit
> ## EPICS R3.14.12-rc1 $Date: Mon 2010-11-15 13:59:06 -0600$
> ## EPICS Base built May 15 2018
> ==END==
Re: VME configuration : MVME6100 can not map slot x to CR/CSR Dirk Zimoch
VME configuration : MVME6100 can not map slot x to CR/CSR 유진성
Prev: Re: Installation of RTEMS and EPICS on MVME6100 Heinz Junkes
Next: Re: EtherCAT newbie question Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VME configuration : MVME6100 can not map slot x to CR/CSR 유진성
Next: Re: VME configuration : MVME6100 can not map slot x to CR/CSR Dirk Zimoch
ANJ, 28 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
