1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Transfering array of 256 elements to driver
To: "[email protected]" <[email protected]>, 'Jörn Dreyer' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 May 2018 13:01:35 +0000
Hi Jörn
> The waveform record supports only INP direction.
The devAsynInt32Array.dbd file defines both input and output.
corvette:asyn/asyn/devEpics>more devAsynInt32Array.dbd
device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
Your waveform record would use DTYP="asynInt32ArrayOut".
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Thursday, May 31, 2018 7:54 AM
To: 'Jörn Dreyer'; [email protected]
Subject: RE: Transfering array of 256 elements to driver
> I'm working on a driver that needs to set 256 values into one hardware
> register. What type of database record should I use for this purpose?
In fact this is not so: you can write in either direction when processing the record, it's up to the device driver to decide whether to push or pull waveform data, so the waveform record will be what you need.
Re: Transfering array of 256 elements to driver Jörn Dreyer
RE: Transfering array of 256 elements to driver [email protected]
Prev: RE: Transfering array of 256 elements to driver [email protected]
Next: Re: Transfering array of 256 elements to driver Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
