1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: MVME3100 FPU Support on RTEMS 4.10.2
To: Matt Rippa <[email protected]>
Cc: "[email protected]" <[email protected]>, Talk EPICS Tech <[email protected]>
Date: Wed, 6 Jun 2018 14:28:58 -0700
On 06/06/2018 02:24 PM, Matt Rippa wrote:
> Thanks for the fast reply. Of all the mvme boards you listed,
> the 3100 hits a nice price point and we're attempting to find
> suitable replacement stock
> ​(quantity 30+) ​
> for the 2700 which are no longer
> manufactured.
Last I checked (~5 years ago) the newer mvme2500 had a price similar to the mvme3100.
The issue was software support.  At the time there didn't seem to be RTEMS board
support.
> Are the 6100 boards on beatnik bsp the only remaining option for RTEMS?
> They cost nearly twice as much and have
> ​shown ​
> thermal regulation issues.
> -Matt
> On Wed, Jun 6, 2018 at 11:10 AM, Michael Davidsaver <[email protected] <mailto:[email protected]>> wrote:
>     Hi Matt,
>     The MVME3100 is based on the MPC8540 processor.  This chip doesn't have an FPU.
>     Other boards do (eg. mvme270x, mvme6100, or mvme2500) and RTEMS supports this.
>     I can certainly confirm that lack of an FPU really hurts performance, even
>     something as (apparently) simple as integer to float.
>     Michael
>     On 06/06/2018 02:03 PM, Matt Rippa wrote:
>     > It appears we've compiled our mvme3100 bsp without FPU support.
>     > We're on the mvme3100 running EPICS 3.14.12.7 and RTEMS 4.10.2.
>     > We're attempting to commission our astrometric kernel control system
>     > and we've run into trouble meeting some of our thread deadlines. What
>     > we've found is a transform routine that takes our mvme2700 ~200 us,
>     > takes the mvme3100 ~8 ms.  So not a surprise to see this with only "-msoft-float"?
>     > 2018-05-31-tcs.log:May 31 11:41:15  E) PORT: tcs_vme, MSG: Welcome to rtems-4.10.2(PowerPC/Generic (*no FPU*)/mvme3100)
>     > Is FPU support possible with RTEMS 4.10.2? If so, what would we need to do?
>     > It looks like there's a multilib on 4.11.2 https://docs.rtems.org/releases/rtems-docs-4.11.2/cpu-supplement/powerpc.html#multilibs(*Eg <https://docs.rtems.org/releases/rtems-docs-4.11.2/cpu-supplement/powerpc.html#multilibs(*Eg>., see #13* )
>     > Here's our bsp specs:
>     > beatnik:
>     > -specs bsp_specs -qrtems -fasm -c -mcpu=7400 -D__ppc_generic -DUNIX -O2 -g -g -Wall
>     > (mvme2700) mvme-2307:
>     > -specs bsp_specs -qrtems -fasm -c -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -DUNIX -O2 -g -g -Wall
>     > mvme-3100
>     > -specs bsp_specs -qrtems -fasm -c -mcpu=powerpc *-msoft-float* -D__ppc_generic -DUNIX -O2 -g -g -Wall
>     > Thank you!
>     > -Matt
Re: MVME3100 FPU Support on RTEMS 4.10.2 Joel Sherrill
MVME3100 FPU Support on RTEMS 4.10.2 Matt Rippa
Re: MVME3100 FPU Support on RTEMS 4.10.2 Michael Davidsaver
Re: MVME3100 FPU Support on RTEMS 4.10.2 Matt Rippa
Prev: Re: MVME3100 FPU Support on RTEMS 4.10.2 Matt Rippa
Next: Re: MVME3100 FPU Support on RTEMS 4.10.2 Joel Sherrill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 06 Jun 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
