1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: RE: EPICS for CompactRio
To: Diego Sanz Hernando <[email protected]>, "Hartman, Steven M." <[email protected]>, Florian Feldbauer <[email protected]>
Date: Thu, 7 Jun 2018 15:52:28 +0000
You have a good presentation on NI website: http://download.ni.com/pub/branches/uk/handson_followup/epics_ral.pdf
There is no alarm on RT target. Some EPICS alarm fields are there, and you can change them with a caput, but it is not enough to make it work.
In addition, I have a LV EPICS solution that is working pretty well on cRIO-9074 (VxWorks) and not starting well on cRIO-9039 (Linux).
Best,
Paul
-----Message d'origine-----
De : [email protected] <[email protected]> De la part de Diego Sanz Hernando
Envoyé : jeudi 7 juin 2018 16:02
À : Hartman, Steven M. <[email protected]>; Florian Feldbauer <[email protected]>
Cc : [email protected]
Objet : RE: EPICS for CompactRio
As another testimony.... I confirm that the best way, in this case, is using an intermediate real IOC, to read from NI shared variables, and have the full EPICS features in the real IOC.... about the first initialization fails, I have had similar behavior.
Regards
Diego
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Hartman, Steven M.
Sent: jueves, 7 de junio de 2018 15:50
To: Florian Feldbauer <[email protected]>
Cc: [email protected]
Subject: Re: EPICS for CompactRio
> On Jun 7, 2018, at 5:18 AM, Florian Feldbauer <[email protected]> wrote:
> I have seen, that NI provides a so called EPICS Server I/O Servers plugin which, as far as I understood, can be used on the CompactRIO system to publish shared variables as PVs to EPICS CA Clients.
> I’d like to know if anyone has experience using the CompactRIO with EPICS?
We are using it. It is functional but it is not a full feature CA server. We are treating it like remote I/O with CA as the field bus. We have other records on an actual IOC that take the cRIO PVs as inputs. Scaling, alarms, etc are all handled by the actual IOC and clients (display manager, alarms, archive) generally interact with the IOC PVs rather than the ones served by the cRIO. One peculiarity we have seen with the cRIO is that the first client that connects does not always get a valid response.
> Does the plugin support fields like HIHI, HHSV, ADEL, MDEL?
HIHI and HHSV: yes
ADEL and MDEL: no
Steven Hartman
[email protected]
P Please consider the environment before printing this e-mail.
______________________
This message including any attachments may contain confidential information, according to our Information Security Management System,  and intended solely for a specific individual to whom they are addressed.
 Any unauthorised copy, disclosure or distribution of this message  is strictly forbidden. If you have received this transmission in error,  please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,  puede contener informacion clasificada por su emisor como confidencial  en el marco de su Sistema de Gestion de Seguridad de la Informacion siendo para uso exclusivo del destinatario, quedando prohibida su divulgacion copia o distribucion a terceros sin la autorizacion expresa del remitente. Si Vd. ha recibido este mensaje  erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
Re: EPICS for CompactRio Paduan Donadio, Marcio
EPICS for CompactRio Florian Feldbauer
Re: EPICS for CompactRio Hartman, Steven M.
RE: EPICS for CompactRio Diego Sanz Hernando
Prev: Re: Controling a slit system with 2 hard and 4 soft motorrs Torsten Bögershausen
Next: Re: Controling a slit system with 2 hard and 4 soft motorrs Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Prev: RE: EPICS for CompactRio Diego Sanz Hernando
Next: Re: EPICS for CompactRio Paduan Donadio, Marcio
ANJ, 07 Jun 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
