Dear All,
I have a device which can be communicated with via serial port but at a strange baudrate of 3062500. This value has been set by the manufacturer and cannot be changed. So, I created a simple IOC using StreamDevice to communicate with it. But when I run the IOC it gives me this: drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyUSB5",0,0,0) asynSetOption("SERIALPORT",-1,"baud","3062500") setOption failed Unsupported data rate (3062500 baud) So, the question is: is it possible to make StreamDevice work with such non-standard baudrate and how? If not, is there any way around it? Thank you. Konstantin ========================================
Dr. Konstantin Kruchinin Researcher ELI-Beamlines Institute of Physics of the Czech Academy of Science Fyzikální ústav AV ČR, v.v.i. Za Radnicí 835 Dolní Břežany 252 41 ========================================
ANJ, 12 Jun 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
