My problem is how to increase the number of elements of an array in waveform record of CA Lab. Below is the waveform record in demo.db, the default number of elements of
an array are 2000.
record(waveform, "caLab:test")
field(DESC, "Double waveform record")
field(PREC,0)
field(NELM, 2000)
field(FTVL, "DOUBLE")
#field(EGU, "mm")
field (PINI, "YES")
I increased the value in the field NELM from 2000 to 30000 ( field(NELM, 30000) ),
an error occured in the terminal:
caLab:test *** CA error The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
Therefore I try to change the default settings in demoIOC.cmd as follows and then restart the demoIOC:
@echo off
set EPICS_CA_MAX_ARRAY_BYTES=1638400000 # I added the line here.
echo start demo IOC now
echo Type 'dbl' to get a list of all available records.
echo Type 'exit' to terminate this session.
echo ---
..\lib\softIoc.exe -D ..\lib\softIoc.dbd -d db\demo.db
:end
However, it doesn't work. No matter what value I set, the same error still exist in the terminal.
Any help will be appreciated and thanks in advance.
Zhefu
ANJ, 14 Jun 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
