1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building aravisGigE on Centos 7
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 30 Jun 2018 14:52:32 -0700
On 06/30/2018 06:41 AM, Mark Rivers wrote:
> Hi Michael,
> Thanks, adding the second line below to the Makefile fixed it.
> PROD_SYS_LIBS += giomm-2.4
> PROD_SYS_LIBS += gio-2.0 gobject-2.0 gthread-2.0 glib-2.0
> I was puzzled why it worked previously when the Makefile contained only the first line, i.e. giomm=2.4.
> I think I have figured it out.  If I add this line to the Makefile it builds fine without the second line above:
> STATIC_BUILD=NO
> If it is building dynamically then libgiomm-2.4.so has the information it needs to know what other libraries are required.  But if I build statically then I need to specify the other libraries.  When this worked previously for me I must have been building dynamically.  Does this make sense?
Yes.  Static libraries (.a files) don't contain the dependency information found in shared object (.so).
So when linking STATIC_BUILD=NO, only the direct dependencies need to be listed (it doesn't hurt to list all).
With STATIC_BUILD=YES, all dependencies must be listed, and in a specific order (direct first).
Re: Problem building aravisGigE on Centos 7 Ralph Lange
Problem building aravisGigE on Centos 7 Mark Rivers
Re: Problem building aravisGigE on Centos 7 Michael Davidsaver
RE: Problem building aravisGigE on Centos 7 Mark Rivers
Prev: RE: Problem building aravisGigE on Centos 7 Mark Rivers
Next: Re: Problem building aravisGigE on Centos 7 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 02 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
