1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is EPICS license GPL-compatible?
To: "Johnson, Andrew N." <[email protected]>
Date: Wed, 11 Jul 2018 08:02:39 -0300
Hello Andrew,
thank you for the answer!
It is good to know that you (as a core developer) don't have objections with GPL. I will keep looking for the answer, probably with FSF too.
Thank you again.
Regards
On 08-07-2018 17:31, Johnson, Andrew N. wrote:
Hi Gabriel,
Disclaimer: I am not a lawyer, and this is not legal advice.
Most EPICS software is distributed as source code, rarely as binaries (there are binary packages available for Debian Linux but they should have source packages available too, and I’m not really talking about them here). The EPICS Open License (EOL) does permit binary distribution with certain conditions though, so some companies sell products including binary versions of the EPICS core code and this is legally fine as long as they follow those conditions.
The question of compatibility between the EOL and the GPL isn’t something we have asked for legal advice over, but I don’t personally have any objections to projects using the GPL, and I think that would be true for all of the current core developers. If there is a legal incompatibility the act of distributing as source code instead of binaries would also prevent problems, because the end-user is the one combining the code and the GPL conditions are only triggered by the act of distribution.
I hope this helps, but I don’t think anyone could give you a definitive answer.
- Andrew
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Is EPICS license GPL-compatible? Gabriel de Souza Fedel
Re: Is EPICS license GPL-compatible? Johnson, Andrew N.
Prev: MEDM compilation on Ubuntu 16.04 Alper Kinaci
Next: Re: Is EPICS license GPL-compatible? Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is EPICS license GPL-compatible? Gabriel de Souza Fedel
Next: Delta Tau Power Brick LV-IMS driver Mark Davis
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
