1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caget randomly returns Channel connect timed out
To: Talk EPICS Tech <[email protected]>
Cc: Tim Gaggstatter <[email protected]>
Date: Thu, 12 Jul 2018 09:54:58 -1000
Hi folks,
We ran a simple caget (once per second) from a linux host to an upgraded IOC. With the new rtems/3.14.12.7 IOC, it often experiences timeouts as shown below. With our legacy vxworks/3.13.9 IOC there are no timeouts logged. Relevant info is shown below. The caRepeater is running on the linux host.
I'm thinking that setting the linux host EPICS_CA_ADDR_LIST=YES may help. I'm running that test now.
Thank you for any insight,
-Matt
linux> cat /etc/redhat-release
CentOS Linux release 7.4.1708 (Core)
linux> uname -a
Linux sbftelops-lv1.cl.gemini.edu 3.10.0-862.el7.x86_64 #1 SMP Fri Apr 20 16:44:24 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
linux> env |grep EPICS
EPICS=/gemsoft/opt/epics
EPICS_BASE=/gemsoft/opt/epics/base
EPICS_HOST_ARCH=linux-x86_64
EPICS_CA_ADDR_LIST=172.17.2.255 172.17.3.255 172.17.102.130 172.17.105.20 172.16.102.130 aom-vme sbfmcao01.cl.gemini.edu mcao-stealth.cl.gemini.edu 172.17.10
6.111 172.17.105.37 172.17.107.50 172.17.55.101 172.17.101.101 172.17.65.255 172.17.102.139 172.17.102.138
linux> caget tcs:ak:astCtx
tcs:ak:astCtx                  0
Channel connect timed out: 'tcs:ak:astCtx' not found.
tcs:ak:astCtx                  0
Our IOC Telescope Control System (TCS) has recently been updated to:
  • RTEMS 4.10.2
  • EPICS 3.14.12.7
  • MVME 2700 (rtems 2307 bsp)
  • VxWorks 5.4
  • EPICS 3.13.9
  • MVME 2700
New IOC Parameters:
tcs-cp-ioc> epicsPrtEnvParams
EPICS_AR_PORT: 7002
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_ADDR_LIST: 172.17.65.255 172.17.3.40 172.17.102.138
EPICS_CA_AUTO_ADDR_LIST: YES
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_MAX_ARRAY_BYTES: 16384
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CMD_PROTO_PORT is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_TIMEZONE: UTC::0::
EPICS_TS_NTP_INET is undefined
IOCSH_HISTSIZE: 20
IOCSH_PS1: tcs-cp-ioc>
Re: caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Andrew Johnson
Prev: NDArrayPool Mark Engbretson
Next: Re: caget randomly returns Channel connect timed out Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NDArrayPool Mark Rivers
ANJ, 12 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
