1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New dxpSITORO module available
Date: Mon, 16 Jul 2018 13:36:13 +0000
Folks,
I have created a new EPICS module called dxpSITORO.
dxpSITORO provides support for the SITORO based digital signal processor based multichannel analyzers from X-ray Instrumentation Associates (XIA). These devices include the FalconXN models, and all contain the functional equivalent of the shaping amplifier, ADC, and MCA of a conventional pulse-height analysis system. The FalconX is based on the SITORO technology from Southern Innovation.  It supports the 1, 4, and 8 channel versions of the FalconX.
dxpSITORO currently supports this hardware under the following operating systems and compilers:
- Linux with gcc.
- Windows with Visual Studio 2015 or later.
Two releases are now available:
Release 1-1 (16-July-2017)
- This is built with Handel 1.1.19 which is required for the new FalconX firmware.
- Added suppport for SCATriggerMode and SCAPulseDuration.
- Added suppport for RisetimeOptimization.
- Fixed IgnoreGate and InputLogicPolarity so they are set for normal MCA mode, not just mapping modes.
- Fixes to Makefiles to allow building dynamically on Windows.
- Renamed some files to avoid conflicts with the dxp module:
  - dxpSupport.dbd to dxpSITOROSupport.dbd
  - Library dxp to dxpSITORO
  - Library handel to handelSITORO
Release 1-0 (17-April-2017)
- Initial release. Supports mca spectrum and mca mapping modes on the FalconX modules. This is built with Handel 1.1.14
The documentation is here:
http://cars.uchicago.edu/software/epics/dxpSITORODoc.html
Release notes are here:
http://cars.uchicago.edu/software/epics/dxpSITOROReleaseNotes.html
Source and releases are available on Github here:
https://github.com/epics-modules/dxpSITORO
Prev: Re: Re: Question about RDB Channel archiver engine be used for the waveform channels lzf neu via Tech-talk
Next: OCEM NGPS power supply unit rory.potter--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
