1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about store array in MySQL by using RDB Channel Archive
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Jul 2018 13:47:23 +0000
Hi:
>    1) There is a waveform array contains 1560 double type elements, I want to store them in mysql in real-time by using ArchiveEngine. To do so, I have imported the mysql_schema.sql  in the attatchment and then start the ArchiveEngine.  However, when performing "select * from sample" command in mysql, only one data are in "float_val" column.  It seems mysql cannot store array directly. Could any one tell me how to store  array in MySQL by using RDB Channel Archive.
The 'sample' table is for scalar data. For array samples, it only holds the first array element.
The complete array is stored as a blob in the 'array_val' table.
See also https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/archive/archive-plugins/org.csstudio.archive.rdb/dbd/array_encoding.txt
Having said that, the archive engine is more of a long-term monitoring tool than a short-term data acquisition tool.
To capture waveforms, you may want to look into the area detector toolset.
>   2) For testing the performance of ArchiveEngine with diffenet parameters (write_period, batch_size, buffer_reserve) versus write speed (samples  per second), could any one tell me how to record the writing speed of ArchiveEngine with  above parameters.
The archive engine's web interface shows
     Last Written   - time when the engine last wrote, typically every 30 seconds
     Write Count   - How many samples it last wrote
     Write Duration  - How long that took in seconds
If you divide Write Count  by Write Duration, you get the basic performance of your RDB setup, i.e. how many values per second you can write.
-Kay
答复: Question about store array in MySQL by using RDB Channel Archive lzf neu
Prev: Re: caget randomly returns Channel connect timed out Dirk Zimoch
Next: Parse IEEE 488.2-1992 Block format with StreamDevice? Christoph Schroeder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Question about store array in MySQL by using RDB Channel Archive lzf neu
Next: 答复: Question about store array in MySQL by using RDB Channel Archive lzf neu
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
