Hi Mark,
If you don't need to worry about Visual Studio versions earlier than 2010 then you could use the VisualStudioVersion environment variable, this was introduced in Visual Studio 2012 so if the variable doesn't exist you could then assume 2010
ifdef VisualStudioVersion
VSNAME=v$(subst .,,$(VisualStudioVersion))
else
VSNAME=v100
endif
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Johnson, Andrew N.
Sent: 29 July 2018 18:50
To: Rivers, Mark L.; EPICS Tech-Talk
Subject: Re: Detect VC++ version in Makefile?
Hi Mark,
There are several ways you could do this directly using GNUmake:
1. Use '$(shell cl -help)' and extract the version number that is included in the compiler's help message, although that's a bit messy since there is lots of other stuff in it too. See Torsten's message for ideas there.
2. Look at the $(VSINSTALLDIR) variable set by the vcvarsall.bat file, which (assuming it's still present in the later versions than I checked) ends with the version of Visual Studio (10.0 etc.). This isn't quite as hard as #1 but there is still other stuff in the string.
3. As part of the build process, compile and run a short C program that prints the desired v100/v120/v140 string (or better still the complete library name) that you're looking for based on the value of _MSC_VER, then have GNUmake use $(shell ...) to run that program and provide the name of the library to be linked with:
PROD_LIBS_WIN32 += $(shell flyCaptureLibs.exe)
See https://sourceforge.net/p/predef/wiki/Compilers/ for the different _MSC_VER macro values.
I think #3 may be the simplest to understand; you have to provide a dependency rule to ensure the program has been built before GNUmake links your PROD. I can help you with this next week if necessary, but it should just be something like:
$(PROD): flyCaptureLibs.exe
You shouldn't have to specify flyCaptureLibs.exe as build target, the above dependency should be enough to build it on demand as long as the source filename is included in SRCS.
HTH,
- Andrew
From: [email protected] <[email protected]> on behalf of Mark Rivers <[email protected]>
Sent: Sunday, July 29, 2018 9:00:04 AM
To: EPICS Tech-Talk
Subject: Detect VC++ version in Makefile?
Folks,
I have a vendor Windows SDK where the required name of the library depends on the version of VC++.
I am currently requiring manual edits of the EPICS Makefile to change the name of the LIB file depending on VS version.
# Add locally compiled object code
PROD_LIBS += pointGrey
# Use this line for Visual Studio 2010
#PROD_LIBS_WIN32 += FlyCapture2_v100
# Use this line for Visual Studio 2013
#PROD_LIBS_WIN32 += FlyCapture2_v120
# Use this line for Visual Studio 2015
PROD_LIBS_WIN32 += FlyCapture2_v140
Does anyone have a mechanism to detect this automatically in the Makefile so this manual editing is not needed?
- Re: Detect VC++ version in Makefile? Mark Rivers
- Detect VC++ version in Makefile? Mark Rivers
- Re: Detect VC++ version in Makefile? Johnson, Andrew N.
Some questions from a first-time driver author Zik Saleeba
<2018>
<2018>
